Author Topic: Horrible noise after heavy braking  (Read 1632 times)
Offline Dizzie
  • Make friends with your fast
« on: 09 June 2014, 10:05 »
When I brake hard from 100+ it sounds like my driveshafts are falling off. Really horrible noises. This only happens after heavy braking though. The noise goes away after 30 seconds of non-braking. The Wheels are hot to touch afterwards
I'm running a 312mm setup with pagid pads and drilled discs. Not sure on disc brand sorry.
I'm thinking perhaps I need some more race pads like green stuff?
Mk4 Golf 150PD
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Horrible noise after heavy braking
« Reply #1 on: 09 June 2014, 10:17 »
Sounds like binding calipers.
Offline Bandit127
« Reply #2 on: 09 June 2014, 15:57 »
Or the abs ring expanding with the heat and contacting something.
It is a graunch or a rattle?
Offline dom
  • Back in a Mk4
« Reply #3 on: 09 June 2014, 17:55 »
Don't do 100+ :lipsrsealed:
Have you got plenty of meat left on your pads?
Offline Bellend
« Reply #4 on: 09 June 2014, 19:42 »
My MK4 did this when I first had it. Stripped caliper wire wheeled piston and it got it going for a while. Inevitably it now is sticking again but I couldn't care less as want new ones anyway.
Bet the caliper is seized.
Where all my moneys went.
Offline Dizzie
« Reply #5 on: 10 June 2014, 12:02 »
pads have loads left on them. checked that last night.
ABS wheel sounds possible. I'll expect the sensor to go down shortly if it's rubbing on that.
It literally sounds like the driveshaft is about to fall off. It's speed related.
Mk4 Golf 150PD
Offline Bellend
« Reply #6 on: 10 June 2014, 12:22 »
Check the driveshaft then!
Mine did sound like it and shook the car and then slowly released. Just corrosion on the caliper piston.
