Author Topic: Best make for cleaning Windscreens  (Read 4816 times)
Offline hastd2
  • Gti the Ultimate Hot Hatch...
« on: 09 June 2014, 07:51 »
Hi guys can you tell me what's the best make for cleaning my windscreen and rain wax stuff aswell
Build Week 11.04.16 - 2016 Mk7 Golf R, Lapiz Blue 5 door manual, 12 months R/Tax, 2 yrs free service, full tank of fuel, sure guard, and private plate transfer
2015 Mk7 Gti 5 DR, Carbon Steel Grey, Performance Pack, Keyless Entry, Vienna Leather, and Sat Nav.
2013 Mk7 Gti 5 DR, Pure White, Performance Pack, Keyless Entry, Vienna Leather, and Sat Nav.
Offline Booth11
Re: Best make for cleaning Windscreens
« Reply #1 on: 09 June 2014, 09:18 »
Subjective, but I like Auto Finesse Crystal Glass Cleaner for inside and out.  Sometimes use Autoglym Fast Glass too.
Occasionally use Rain X Rain Repellant on windscreen, which beads lovely but find it often makes wipers judder and squeak so now I tend to leave front windscreen free of anything, after cleaning.  All other exterior glass gets waxed along with bodywork, so whatever wax I'm using at the time.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Ginge 35Edition
« Reply #2 on: 09 June 2014, 09:22 »
I don't out anything on my windscreen very often due to the reasons above.
Offline SI74
« Reply #3 on: 09 June 2014, 20:17 »
Hard to beat Dodo Juice Clearly Menthol Glass Cleaner
And
Hydrophobe from Orchard Auto Care.  Needs to be a dedicated product thats been designed for windscreens.
Offline dragonfly
« Reply #4 on: 10 June 2014, 19:04 »
DJ Clearly Menthol is a very good cleaner.  Try H2G0 by Angel Wax as a rain repellant - another good and effective product.
Offline Bandit127
« Reply #5 on: 10 June 2014, 19:35 »
I started off with Turtle Wax glass cleaner and it took me
1 application to find out it is best for external use only (it smeared a lot)
Ages to work out that it does what Rain-X does.
I have got used to it now and I like it. Because it has a slight filler effect it also helps match out light scratches and small chips (while it lasts).
For juddering wipers - check your arms are bolted tight and the blades are held securely.
If all this checks out then your wiper blade is not at exactly 90° to the windscreen surface. In the direction of judder the blade is held at such a steep angle that it cannot fold over and slide freely. Instead it digs in, pings back and bounces, digs back in etc. The cure is simple. You need to twist the arm so that the blade is 90° to the windscreen.
I did this on mine this weekend. The arm is quite springy so it needs quite a lot of force before it will actually twist. I used a large adjustable to get good purchase on the arm and took great care not to knock the windscreen.
Offline Booth11
« Reply #6 on: 10 June 2014, 20:14 »
I only ever get wiper judder when I use products on the windscreen.  If I just wash the windscreen and leave it free of anything, I don't get it at all.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Stevie35
« Reply #7 on: 10 June 2014, 23:43 »
I currently use Autoglym glass polish it's one of the best I've used, but a little goes a long way and polishing until there is almost no product left makes it easier to buff so the glass is sparkling. Then apply 3 coats of rain-x apply 2 coats first then wait around 30min to an hour and apply the third. You can also put rain-x on side windows to help water run off to keep them clear. I would go for 3 coats on windscreen and front door glass and 2 coats on rear glass and rear screen. That should last around 2 months.
Wiper judder normally goes away after a couple wipes, I had it after applying G-techniq to my glass but went away after 3 sweeps of the blades
« Last Edit: 10 June 2014, 23:50 by Stevie35 »
Edition 35 3dr, Steel Grey, Manual, Sat Nav
Offline hastd2
« Reply #8 on: 11 June 2014, 06:59 »
Thanks guys for the feedback on the stuff you find best, I have ordered a few bottles, Dodo Juice Clearly Menthol Glass Cleaner, and a Rain X 2 in 1 Glass Cleaner and Rain Repellent 500ml Trigger...hope these work a treat  :whistle:
Offline Organisys
  • Old and Slow...
« Reply #9 on: 18 July 2014, 13:21 »
Wash, Clay, Polish, IPA or Panel Wipe followed by Gtechniq G1.
Repeat after about a year.
 :wink:
