Author Topic: sump plug  (Read 3836 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: sump plug
« Reply #10 on: 09 June 2014, 23:14 »
thay cancel the payment so not getting it now
I purchest this instead http://www.ebay.co.uk/itm/Stahlbus-Oil-Drain-Valve-M14-x-1-5mm-Thread-/371065131557?pt=UK_Motorcycle_Parts_13&hash=item5665349225
I think I may have to invest in one of these myself.  :smiley:
Offline rockmonkey69
Re: sump plug
« Reply #11 on: 09 June 2014, 23:27 »
I highly rate it, the fitting and supplied hose makes it easy to collect the oil in a can with no spillage. As my oil filter isn't over lightly tight either, I can do an oil change without the need for any tools.
Re: sump plug
« Reply #12 on: 10 June 2014, 08:18 »
Yeah im liking this idea  a lot as it'll mean il change the oil more frequently if theres less faff and mess outside my house.
Offline Scottymk4
Re: sump plug
« Reply #13 on: 10 June 2014, 13:04 »
i like this idea to...maybe then would do my own oil changes
Offline leigh_harty
  • Audi AGU
Re: sump plug
« Reply #14 on: 10 June 2014, 17:06 »
Does it pose any threat with lowered cars though?
Dont lose your dinosaur!
Offline viperjsy
Re: sump plug
« Reply #15 on: 10 June 2014, 17:09 »
no it wont
Re: sump plug
« Reply #16 on: 10 June 2014, 18:44 »
I think the one with lever posted first has a higher potential for getting caught on something as it sticks out quite far with that extension piece. The second one looks quite low profile though.
Re: sump plug
« Reply #17 on: 10 June 2014, 21:03 »
I never caught it off anything before but I'm not low enough to scrape my sump. There are bits of the sump that are lower than the drain valve, so it's not the lowest point.
Offline brianpologti
Re: sump plug
« Reply #18 on: 12 June 2014, 11:02 »
You should get a pump
Like http://m.screwfix.com/p/laser-oil-fluid-extractor-6ltr/21663
Yes I know you can get it cheaper elsewhere
Re: sump plug
« Reply #19 on: 12 June 2014, 11:24 »
I'm a bit old fashioned, I like to know if there are any serious issues with my motor, if there are metal filings/shavings/lumps of metal in the oil I would like to know. My concern is that the pump might not be able to pick up shavings from the bottom of the sump if there were any. Touch wood all goes well, it's been perfect 15k after I rebuilt it and it's unlikely by now anything goes wrong, but I like to check after each oil change.
Just out of curiosity where does everyone stick the pump to suck the oil from? I've never used one before
