Author Topic: sump plug  (Read 3837 times)
Offline viperjsy
sump plug
« on: 08 June 2014, 18:06 »
hi I have purchest this
to put on when I wire up my oil temp gauge
it is a Fumoto oil drain valve from ecs tuning
« Last Edit: 08 June 2014, 18:10 by viperjsy »
Offline Scottymk4
Re: sump plug
« Reply #1 on: 08 June 2014, 18:13 »
Does this replace the sump plug?
Offline viperjsy
Re: sump plug
« Reply #2 on: 08 June 2014, 18:21 »
yes it dose here is a link to the web site it has a video http://www.ecstuning.com/ES2208993/
« Last Edit: 08 June 2014, 18:23 by viperjsy »
Offline rockmonkey69
Re: sump plug
« Reply #3 on: 08 June 2014, 18:33 »
That's similar to mine, only mine doesn't have a lever, it seals with a spring loaded bearing instead.
« Last Edit: 08 June 2014, 18:37 by rockmonkey69 »
Offline viperjsy
Re: sump plug
« Reply #4 on: 08 June 2014, 18:36 »
I have seen that type on ebay is the cap easy to get off
Re: sump plug
« Reply #5 on: 08 June 2014, 18:39 »
Yes it's just finger right, it's only a dust cap to stop grit and water making it's way into the orifice or any of the mechanism.
Offline viperjsy
Re: sump plug
« Reply #6 on: 08 June 2014, 18:41 »
ok thank you
Offline viperjsy
Re: sump plug
« Reply #7 on: 09 June 2014, 16:23 »
« Last Edit: 09 June 2014, 17:22 by viperjsy »
Re: sump plug
« Reply #8 on: 09 June 2014, 21:29 »
Yea that's the one I use, it makes oils changes more clean and quick.
Offline viperjsy
Re: sump plug
« Reply #9 on: 09 June 2014, 22:08 »
thank you
