Author Topic: replacement xenons have arrived... how do I install the left one though?  (Read 4030 times)
Offline candywhite12
hi all
after a lot of light-less nights, osram xenarcs have finally arrived to replace the dead OEM ones.  I can very easily take out the driver-side one and replace it.  Can anyone help on how to replace the passenger-side one though?  I can 'unlock' the OEM one from its place but there is not enough room to take it out altogether since there's a box full of fuses right behind the headlight that pretty much blocks space.
Any help much appreciated
thanks
Wife's: mk8 TSI 1.4 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Now: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline Mattyj
I removed the airbox on mine
no that doesn't cut it.  removing the airbox only frees space to replace the signal bulb, not the headlight one.  That is blocked by that fuse box... anyone else??
Offline Buck
  • Das Auto
Hi
I'm sure that you have to loosen the headlamp unit and pull it forward slightly.
I would mark how the headlamp is currently aligned so that you can put it back to the same line.
Offline Buck
  • Das Auto
Edit: just found this via google which might help?
http://www.golfmk6.com/forums/showthread.php?t=78650
Buck, this is exactly what I was looking for.  I spent hours yesterday googling this and nothing this good came up.  Much, much appreciated mate
Offline mike.
When I changed mine I just removed the fuse box, it was fairly simple if I remember.
I don't remember having to loosen the light, just remember there is a screw at the bottom of the light which you can't get at unless you remove the bumper, so too much movement with only the top ones removed will break the bracket at the bottom.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
removing the fuse box was my initial thought. Do you remember specifics?  any precautions i need to be aware of?
Offline mike.
Just as long as you disconnect the negative battery terminal
I think there is a multipin plug holding two halves of the fuse box together.
I have the details at home but I wont be back there for 5 or 6 hours..
anytime you can send the info would do mate cheers
