Author Topic: Front seat belts  (Read 1516 times)
Offline dadrathers
Front seat belts
« on: 06 June 2014, 20:34 »
The passenger seat belt must be pristine on most cars whereas the driver's side is well worn - mine is anyway. Has anybody tried to cannibalise a left and right hand seat belt to swap the LH belt onto the RH mechanism?
Offline dubber36
Re: Front seat belts
« Reply #1 on: 07 June 2014, 13:28 »
Without going into the garage to look at my car, is there a difference between the left and right hand belts?
The rears are different as they are mounted at an angle and they won't unwind if they are not in the right position. The reels on the fronts mount vertically, so I can't see what difference it being fitted on the other side would make.
Offline dadrathers
« Reply #2 on: 07 June 2014, 18:47 »
There is a difference on a more door like mine. ETKA lists LH and RH for five door cars but only lists one for the three door.
