Golf mk4
Wazzzer
bora sport clocks
Topic: bora sport clocks (Read 3150 times)
Scottymk4
Here all the time
Re: bora sport clocks
Reply #10 on:
04 June 2014, 21:34 »
Barry it's a t 99 plate
Scottymk4
Here all the time
Reply #11 on:
04 June 2014, 22:23 »
tried changing the soft code from 00006 to 00004 but for some reason it wont change....any ideas
Scottymk4
Here all the time
Reply #12 on:
05 June 2014, 12:36 »
do I need to use the pin for the clocks first to let me make the changes to the soft coding
topher
Administrator
Serious forum addict
fully functioning
Reply #13 on:
06 June 2014, 19:55 »
no you dont need the pin for soft coding. quick google shows my memory isn't amazing
http://uk-mkivs.net/topic/95233-cluster-coding-immo2-to-immo3-upgrade/
subtract 4 from the soft coding to remove airbag comms.
Scottymk4
Here all the time
Reply #14 on:
06 June 2014, 21:17 »
Thanks mate that worked a treat, this doesn't switch off the airbags does it ?
topher
Administrator
fully functioning
Reply #15 on:
06 June 2014, 23:42 »
nope, just tells the cluster to stop looking for a can signal from the airbag module
Scottymk4
Here all the time
Reply #16 on:
07 June 2014, 08:02 »
Thanks topher, another question I have is for some reason the mpg figures dont change....one is stuck at 99.9 the other is blank and also MTE seems to go up and not down... Everything else seems to work
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #17 on:
07 June 2014, 11:57 »
I'm sure Ray told me that the correct readings are dependant on the ECU you have with the AGU...
Mine all works fine on my '99 AGU, I have the 018 CG ECU
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Scottymk4
Here all the time
Reply #18 on:
07 June 2014, 12:47 »
Wazzer just been told could be cause my car is non canbus and immo3 clocks are canbus bit to complicated for me lol how do I know which ecu I have can I find this info on vagcom?
topher
Administrator
fully functioning
Reply #19 on:
07 June 2014, 12:56 »
go in to engine with vagcom it shows the part number in the top left field, it will be something like 06A 906 018R, i think the 018CG is the canbus version.
Golf mk4
Wazzzer
bora sport clocks
