Author Topic: bora sport clocks  (Read 3151 times)
Offline Scottymk4
bora sport clocks
« on: 04 June 2014, 20:16 »
hey guys, fitted new clocks tonight and now the airbag light staying on...vagcom saying cant connect to the module...any ideas?
Offline davidgtrr34
Re: bora sport clocks
« Reply #1 on: 04 June 2014, 20:18 »
Did u check the fuse  :grin:
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Scottymk4
« Reply #2 on: 04 June 2014, 20:19 »
no... :rolleyes: why would fuse have blown
« Last Edit: 04 June 2014, 20:27 by Scottymk4 »
Offline Scottymk4
« Reply #3 on: 04 June 2014, 20:53 »
Another problem seems to be the warning light in the middle seem strange... The door open one only half lights up  :angry:
Offline davidgtrr34
« Reply #4 on: 04 June 2014, 21:02 »
When you wired them did u unplug anything
Offline Scottymk4
« Reply #5 on: 04 June 2014, 21:06 »
Only the clocks mate
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 04 June 2014, 21:20 »
i would guess you have an AGU so go in to can gateway and change the soft coding to remove the airbag light. your new clocks are looking for the airbag module over CAN which it sounds like your car doesn't have.
Offline Scottymk4
« Reply #7 on: 04 June 2014, 21:24 »
I do have an agu.... Can you give me a step by step please
Offline barrym381
« Reply #8 on: 04 June 2014, 21:29 »
what plate is your car  :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 04 June 2014, 21:30 »
with vagcom go in to the can gateway module (address 19) and click soft coding. it will probably be something like 0006 i think it needs to be changed to 0004. when you hover the mouse cursor over the coding field it should pop up the suggested coding anyway.
