Author Topic: 1.4 brake upgrade  (Read 5059 times)
Offline Mattb1123
1.4 brake upgrade
« on: 01 June 2014, 21:43 »
Hi all, ive just got myself a 1.4se
ive been offered a mk4 golf 288 set up (calipers, carriers, discs, pads) cheap by a friend and i was wondering if they would fit.
Am i right in thinking i will need to upgrade to 5x100 hubs before i can fit these, If so what else is needed other than the hubs.
Any help welcome.
Thanks Matt
« Last Edit: 04 June 2014, 20:55 by Mattb1123 »
Offline tweed
Re: MK4 Brake upgrade
« Reply #1 on: 02 June 2014, 00:32 »
You dont need them mate. Only thing they will do is slow you down due to the extra unsprung weight.
A decent pad is all you need.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 02 June 2014, 10:34 »
I will add yes you need to go 5 stud but also they wouldn't bolt directly on, you would either need to space the carrier to get the offset right or only use the calipers and pads and use mk3 gti carriers and discs
oh and you would also need new brake hoses as they use banjo fittings
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 02 June 2014, 18:16 »
Simply not worth the effort of installing the long list of parts needed unless you're planning to change the engine as well.
Offline Mattb1123
« Reply #4 on: 02 June 2014, 21:39 »
could anyone begin to list the parts i need so i know what im up against.
I know i probably dont need them but is it a silly thing to say you want bigger brakes not just for performance  :grin:
Offline Foreveryoungaus16v
« Reply #5 on: 02 June 2014, 21:49 »
Waste of time for a 1.4 current brakes are more then enough.
« Last Edit: 02 June 2014, 21:51 by Foreveryoungaus16v »
163 BHP (TSR POWER RUN)
Offline Mattb1123
« Reply #6 on: 02 June 2014, 21:52 »
i wanted bigger brakes for looks more than anything
« Reply #7 on: 02 June 2014, 21:54 »
 :grin:
  • Back in a Mk3...
« Reply #8 on: 02 June 2014, 22:02 »
Well you can either go 5 stud mk3 set up or go for 280mm G60 spec mk2 brakes..
neither option is cheap, but the mk4 set up wont fit without lots of spacers and you still need the 5 stud conversion
Offline Mattb1123
« Reply #9 on: 02 June 2014, 22:06 »
id prefer 5 stud option as it makes wheel choice easier too  :smiley: Thought id just ask about the mk4 set up because it was offered to be cheap by a friend.
