Author Topic: Updating RNS510  (Read 3494 times)
Offline seabrook132
Updating RNS510
« on: 30 May 2014, 20:25 »
Hi all,
Ok so I'm looking to upgrade the firmware and maps on my RNS510. I have a version F currently running firmware version 3970 and map version 7690 (Western Europe V8). From the reading I have done so far, the firmware should be updated first and in increments. So I should go through v3980, v4020, v5218 then v5238 to finally get to v5269, does this sound correct? (I'm looking here for the versions http://www.my-gti.com/3868/volkswagen-rns-510-firmware-download-repository)
Also do I need to do any coding after firmware updates? I have no parking sensors or camera but I do have MDI and the VW accessory bluetooth kit. Will updating mess any of these up or the buttons on the steering wheel?
As for the maps do I need to update incrementally with these as well i.e go to V9 before updating to V10?
Any help and advice much appreciated :)
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline mcmaddy
Re: Updating RNS510
« Reply #1 on: 15 June 2014, 09:02 »
If you are already on 3970 then just go to 4020 and then 5269. Just remember to reset the rns after each update. You may need to re code the mdi and Bluetooth but you won't know until you've updated. As for your maps skip v9 and go straight to v10. Again remember to reset after updating.
Offline seabrook132
Re: Updating RNS510
« Reply #2 on: 15 June 2014, 15:24 »
Cool, thnx for your help :)
