Author Topic: service  (Read 2179 times)
Offline cartoonhead
service
« on: 29 May 2014, 21:11 »
Wanting to service my 2001.golf 1.8t gti myself for the 1st time, how hard can it be...what gear will I need?  I haven't got a Danny laroo,any help is much appreciated,
Offline itavaltalainen
Re: service
« Reply #1 on: 29 May 2014, 21:13 »
get a haynes and work through the list....
if you haven't done car servicing before get a mate to give you a hand, most stuff isn't too tricky to work out but helps if you have someone who knows a few tricks and saves you busting your knuckles...
Offline cartoonhead
Re: service
« Reply #2 on: 29 May 2014, 22:00 »
Thanks for the info
Offline clancy
Re: service
« Reply #3 on: 01 June 2014, 11:17 »
Need an oil pan, standard tools and a trolley jack and a service kit obviously
Easy as piss :) must be a guide online or if not get a Haynes manual
MK3 GTI 16v
Offline Bandit127
Re: service
« Reply #4 on: 01 June 2014, 17:57 »
Good call by Clancy. Trolly jack and/or axle stands.
Do not trust the standard jack if you are working under the car. It is unstable and not to be trusted for a second on level solid ground. Let alone any ground that is not solid or level.
