Author Topic: TIP & FMIC HELP!  (Read 1407 times)
Offline Mr-B
TIP & FMIC HELP!
« on: 29 May 2014, 00:23 »
Ok so i now have fitted the toyosports intercooler.. What a nightmare.. Pipes not fitting correctly. and i now fear there is a outlet valve that will need to be moved..
I bought a creation motorsports TIP but i have forgotted where everthing should go and what pipes should connect where. and i noticed some oil spraying out the pipe.
Im really stuck here as there is a small outlet from the intercooler pipe which i believe should connect to the n75 valve. as you can see dew to the possition of the outlet on the intercooler I have has to splice in a peice of pipe..
i really need some help on how to plumb all this back into the car. was far too quick pulling it all out now im lost..
many thanks in advance
« Last Edit: 29 May 2014, 00:26 by Mr-B »
Mk4 AGU 1.8T, JOM Coilovers, Creation Motorsports TIP, FMIC 2.5", WhiteLine ARB, WhiteLine Droplinks, Brembo Drilled & Grooved F/R, Forge Spacers, K&N Oil Filter, Forge Catch Tank, ECS Dogbone Mount, Custom Side Exit 2.5" (Work In Progress)
Offline Dalo Harkin
Re: TIP & FMIC HELP!
« Reply #1 on: 29 May 2014, 12:36 »
Ok so on your TIP at the top you have 2 places to put the DV and the Hockey puck, and then you want to run the pipe that comes out the other side of the DV into the new intercooling pipe.
Offline Mr-B
« Reply #2 on: 29 May 2014, 12:47 »
Thank you for the advice . So where should the pipe from the n75 valve go? I have the plastic bit pushed into one of the small pipes on the tip but there is still a rubber hose from it and no where to fit it.
Thanks
Offline viperjsy
« Reply #3 on: 29 May 2014, 21:03 »
hi hope this helps
