Author Topic: Golf mk4 1.8t agu ecu issue  (Read 2723 times)
Offline Mxmad46
« on: 22 May 2014, 20:57 »
Hi im hoping some one could shine some light on this for me!
I had a 06a906018r ecu in my golf, i bought a remap chip and messed up the install rendering my ecu usless and myself with no car! I was told to buy a new ecu and get it immo deleted! So i was giving the name of a so-called reputable vw guy who said any ecu with the same numbers would work fine the letters on the end dont matter? So i asked prior to buying a ecu would a 06a906018cl be ok and run in my car and he said yeah would be fine! So..... Bought ecu travelled 50 miles to get it unlocked got home plugged it in and
Offline Mxmad46
Re: Golf mk4 1.8t agu ecu issue
« Reply #1 on: 22 May 2014, 21:04 »
Running on 2 cylinders and will only idle if maf is unplugged! I have swapped coils and plugs but no change! Car ran perfect last week! Can someone advise if this would be due to a incompatible ecu or even if you can tell me if another ecu is even compatible of being installed like i was told  please help me :o i have no car and ran out of ideas
Offline bob23
  • Hi, for those of you that don't know, I'm a tw@!
« Reply #2 on: 29 May 2014, 20:01 »
Hi, the most likely problem is that the replacement ecu is no good, did the bloke who removed the immobilizer bench test it?
Current cars 1995 Golf gti colour concept 2.0 8v 156,000 miles. bmw 316 1.9 129,000. yeah, life's good! :rolleyes:
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 29 May 2014, 20:13 »
018CL is for a non turbo 1.8 20v. Depending on the chip type you might be able to clone a 1.8T ecu on to it, but its easier just to get the right ECU. No need to remove the immobiliser you can code AGU ecus to work with vagcom in 2 minutes, no pin codes or logins needed.
Offline Chris.
« Reply #4 on: 29 May 2014, 20:39 »
As above,  sooo easy to code immo 2 AGU ECU's in with VCDS.
Too many of these I can do anything to any ECU people about these days. :(
Click For Build Thread
