Author Topic: rusted nut on fuel filter  (Read 4028 times)
Offline sharki786
  • GOT BOOST??
« on: 21 May 2014, 09:18 »
I need to change the fuel filter on my car as its never been changed. Now i am having misfiring problems, ive been told to change it. Now problem is that i tried and i snapped a bolt on the filter cage, now theres only one bolt left thats holding it. I have sprayed some plus gas on it but if that dont work i have some acid at work that i can dab on the nut. Say if it breaks is it easy to get to drill a hole and use a bolt and nut from the passangers foot well or is it further under the seat base?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: rusted nut on fuel filter
« Reply #1 on: 24 May 2014, 20:06 »
Anyone?
*****MK4 GTI T*****
Offline itavaltalainen
« Reply #2 on: 24 May 2014, 20:41 »
Wouldn't worry, won't fall off even with just one bolt.
http://www.vagcat.com/p/B121/201400.png
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 24 May 2014, 20:42 »
Thing is that it needs changing
*****MK4 GTI T*****
« Reply #4 on: 24 May 2014, 22:06 »
Just don't snap the second one then  :grin:
What did you use to undo the first one? I changed it on my 94 estate about 4 years ago.... and that was pretty rusted... but got it off ok with ring spanner and hammer OK after just soaking it for 10 mins with ballistol
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 24 May 2014, 23:02 »
I sprayed some plus gas on it a few weeks ago. Need to spray abit more again. Last time i used a socket and it just snapped off. Then when i wnet for the 2nd one the whole thread was turning
*****MK4 GTI T*****
VW BUSH
« Reply #6 on: 25 May 2014, 15:26 »
Use a big F^ck off blow torch to loosen it up :evil:
Offline Bandit127
« Reply #7 on: 25 May 2014, 19:08 »
LOL - on a fuel filter housing?
Probably do the job but it might have some unintended side effects...
« Reply #8 on: 25 May 2014, 21:55 »
it's a mk3. they are meant to catch fire  :evil:
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 26 May 2014, 10:18 »
Bunch of tats :grin:
I already thought about that. :lipsrsealed:
*****MK4 GTI T*****
