Author Topic: R tech stage 2 on Friday  (Read 4654 times)
Offline Dalo Harkin
Re: R tech stage 2 on Friday
« Reply #10 on: 21 May 2014, 12:47 »
I know the new OEM one is meant to be uprated but surely an OEM vs a Forge there is no question - I wouldn't risk it with a stage 2 - stage 1 you might get away with it
What is that based on?
Stage 1 I ran a standard actuator and it wasn't up to the job (unknown amount of time it had been on the car), upgraded to a forge (green spring) ran ok, needed a yellow spring for the stage 2 as it wouldn't keep it closed, so its based on my own events and circumstances nothing else.
Offline baka
« Reply #11 on: 21 May 2014, 18:45 »
I thought the standard engine wanted 98RON anyway?
Putting 95RON in a stage 2 car? Madness I tell you!  :laugh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 22 May 2014, 23:27 »
Higher octane fuel needs to be run for a few tank fulls to allow the ECU to adapt
Offline Chris#101
« Reply #13 on: 24 May 2014, 13:01 »
Tesco 99' and methanol :evil:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline andy68
« Reply #14 on: 24 May 2014, 15:33 »
Why put 95 RON in a stage 2 car, thought the idea behind stage 2 was to get the best out of your car. 95Ron OK for completely standard car and generic map, just my opinion.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 24 May 2014, 17:03 »
With 95 on a 98RON map it will retard the ignition timing creating a hotter mix and less power...
Offline paultownsend
« Reply #16 on: 24 May 2014, 22:05 »
Full spec and results!
Offline james18t
« Reply #17 on: 24 May 2014, 22:29 »
I had mine stage 2 mapped by R-tech on 99 last year and they told me it's not safe for the engine to put 95 in anymore.
« Reply #18 on: 25 May 2014, 14:19 »
James. If you don't mind me asking, what is your spec, and what results did you get at r tech?
The fuel debate is surely obvious. Vpower is the only option. Miles to tank it works the same. I got mine mapped on the ko3 on supermarket fuel. Big regret as now I use vpower, it's not at it's best. No logged through VCDS and not a sign of knock.  Ports and valves are nice and clean too.
If I have to use supermarket fuel I unplug the. N75
Offline james18t
« Reply #19 on: 25 May 2014, 17:48 »
Milltek 2.5" cat back with discreet tailpipes & 2.5" decat downpipe
PVC simplification (N249 delete, SAI delete) and oil catch can install
Forge 008p
Forge silicone TIP
Forge wastegate actuator
THS front mounted intercooler & high flow pancake pipe
VR6 clutch & G60 flywheel
Cold air induction kit with K&N cone filter
NGK Iridium spark plugs
They put a few extras on as well, like launch control, linear throttle and a switchable map with 5 different settings, it's pretty cool and had no problems at all in the year and a bit that I've had it.
