Author Topic: R tech stage 2 on Friday  (Read 4669 times)
Offline dane
« on: 18 May 2014, 19:20 »
Hey guys just wondering if there is any checks or anything u can think off that I should do be for taking long drive from Devon to rtech on Friday any thing u can think off be great just worred I'm going to get there and they say they can't do it :/ thanks Dane
Offline dom
  • Back in a Mk4
Re: R tech stage 2 on Friday
« Reply #1 on: 18 May 2014, 19:37 »
I'd check all the basics like all fluid levels, visual check of all boost/vac lines, new air/fuel filters if they haven't been changed in a while, check your plugs, scan for fault codes etc.
Also make sure you're running it on V-power or Tesco Momentum 99 fuel.
Offline Bandit127
« Reply #2 on: 18 May 2014, 19:43 »
I would clear your codes (if you have a code reader or VCDS). Any that are logged will be fresh and current.
Obviously the engine will make multiple runs to the red line, so I would want to know my oil and filter are up to it.
Offline paultownsend
« Reply #3 on: 19 May 2014, 07:52 »
What spec is the car for stage 2?
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 20 May 2014, 12:19 »
they will check the car to make sure all the boost pipes are in good condition and there are no leaks and give the engine a general health check before they start.
Mk4 Golf 150PD
Offline Dalo Harkin
« Reply #5 on: 20 May 2014, 12:51 »
as the others have said, check the fluid levels, fault codes, etc.
Run decent fuel - Shell Nitro+ or whatever it is gets my vote but you can also run Tesco 99 if you must  :grin:
Remember you'll need an uprated actuator (forge) and check the actuator and DV have yellow springs in
Offline dom
  • Back in a Mk4
« Reply #6 on: 20 May 2014, 17:53 »
Uprated actuator isn't essential, rtech now recommend a new oem actuator if the car has done high miles.
Offline Dalo Harkin
« Reply #7 on: 21 May 2014, 08:28 »
I know the new OEM one is meant to be uprated but surely an OEM vs a Forge there is no question - I wouldn't risk it with a stage 2 - stage 1 you might get away with it
Offline dom
  • Back in a Mk4
« Reply #8 on: 21 May 2014, 10:32 »
What is that based on? This is a quote directly from R-tech regarding Stage 2 requirements:
Quote
Decent strong actuator Pressure is key to the higher numbers, an actuator with 100+k on it will not make the higher stage2 numbers due to the spring getting weak, where a new oem actuator will do 250+bhp.
I can forward you the e-mail if you like.
Offline Dizzie
« Reply #9 on: 21 May 2014, 10:59 »
personally I wouldn't put 99RON fuel in JUST for 1 day of remap. if you run 99RON all the time anyway then great, but if you usually only put 95RON in getting it mapped to 99 and then refilling it with 95 doesn't make much sense to me.
The map will be tailored to the higher octane and behave badly once you return to 95
Mk4 Golf 150PD
