Author Topic: Another heater problem...  (Read 2886 times)
Blue MK2
« on: 19 October 2003, 23:08 »
My heater gets hot instantly wich is good.
But........
After a few minutes the heater slows down and then cuts out.
Then.....
when i go over a bump after about 5 mins the heater come back alive again ???
when the heating slows down it makes a rough noise which sounds like a 'nakkerd' motor?
Any clues?
golfvr6
Re:Another heater problem...
« Reply #1 on: 19 October 2003, 23:12 »
The bearing in the motor has gone maybe ? may need a new blower unit, about 200 bar i think.
Blue MK2
« Reply #2 on: 19 October 2003, 23:13 »
FLIPPIN EKK! ABOUT 200 BIG ONES? IS THIS ITEM EASY TO NIK FROM THE SCRAPPY?    LOL :o
Blue MK2
« Reply #3 on: 19 October 2003, 23:15 »
Where is this dodgy item located? Is this the item in the engine bay under the black plastic cover?
golfvr6
« Reply #4 on: 19 October 2003, 23:16 »
Do you mean the blower stops working completely? if so check the electrical connections. If you need a to replace it then a scrappy is worth a try.
Offline Gambit
« Reply #5 on: 20 October 2003, 13:31 »
i half-inched one out of the scrappy!! as the bearing in mine had gone causing it to make a nice whirring sound
they are located below the glove box, you need to take of the plastic tray then you'll see it on the left.
to remove it, there is a clip at the back of it, u a screwdriver to undo the clip, then rotate it anticlockwise and it should come out
if yours just stops & starts then its probably just a loose connection
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 20 October 2003, 13:51 »
do u even have to take that shelve out under the glove box? I think with mine it's just a unscrew and remove. Knowing me I've left out some screws and clips in a previous fix. ;D
