Author Topic: vr6 vag com fault code  (Read 2434 times)
Offline mush
« on: 16 May 2014, 22:07 »
so ive plugged my vr6 in today and it came back with error code
1 fault found engine speed sensor (g28) no signal  :undecided:
ive had a search around and phoned gsf for a price = £35.00 for a new sensor, however after a few searches
people who have the obd1 aaa engine have said its perfectly normal as your not driving and its only being tested on ignition.
can someone pop on and tell me the right info. I don't want to go out and buy a speed sensor
until I know for sure  :smiley:
MK2 golf 16v :-)
Offline itavaltalainen
Re: vr6 vag com fault code
« Reply #1 on: 16 May 2014, 22:22 »
Did you test it with only ignition on or the engine running?
Offline mush
« Reply #2 on: 17 May 2014, 09:29 »
its was just tested on ignition, i didnt have the engine running.
MK2 golf 16v :-)
« Reply #3 on: 18 May 2014, 18:44 »
try again with it running then....
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #4 on: 18 May 2014, 20:56 »
Yes the engine speed sensor will throw the g28 engine speed sensor no signal code when scanned with just the ignition and not running on all obd1's and some obd'2's. If that sensor was faulty it would be likely to show it as 'intermittent' and have noticeable running issues if it ran at all.
Offline mush
« Reply #5 on: 19 May 2014, 11:11 »
grerat cheers guys, i dont think it came up with intermittant but i'll check. so no other fault codes i was waiting for a big list to pop up.... :whistle:
im only using vag-com light so its a bit limited...i dont fancy paying for the full version really..ive used it on my girlfriends polo and cleared a code that hasnt come back  :smiley:
its amazing you can get all sorts of info.
MK2 golf 16v :-)
