Author Topic: Cold AIr Intake Install Help  (Read 3258 times)
Offline Sonic B0000M
  • 1.8 T AUM 205BHP
« on: 13 May 2014, 19:55 »
Where does this pipe go to. Any pictures? Take it, it goes from the metal inlet pipe to somehere.
Offline dom
  • Back in a Mk4
Re: Cold AIr Intake Install Help
« Reply #1 on: 13 May 2014, 20:13 »
Any pictures of what you've got in place so far?
  • 1.8 T AUM 205BHP
« Reply #2 on: 13 May 2014, 20:17 »
Nothing yet. This is the kit
  • 1.8 T AUM 205BHP
« Reply #3 on: 13 May 2014, 20:20 »
I've figured out from this picture where the small Filter goes.
This is not my golf
« Last Edit: 13 May 2014, 20:22 by Sonic B0000M »
Offline Kruga
  • Silver - MK4 1.8T AGU 2000
« Reply #4 on: 13 May 2014, 21:19 »
I bought the same direnza cold air intake kit and i didnt even put that small filter on i couldn't figure out where i went so i never bothered with it this was over 4 months ago and no problems yet haha
Offline benmanc
« Reply #5 on: 13 May 2014, 22:51 »
Agu dont have the small one
Offline Dalo Harkin
« Reply #6 on: 15 May 2014, 12:16 »
what you are 'meant' to do is put the silver reducer onto the SAI pipe which is on the pic you put up of someone else's has the small filter on, and then that other side of the reducer attached to one end of the blue pipe and then that connects to the aluminium tube
  • 1.8 T AUM 205BHP
« Reply #7 on: 15 May 2014, 17:39 »
Decided not to run the cold air from behind the bumper as i don't want to suck up water, so placed it here.
Also put on a Forge splitter on but i have definitely lost some power, not massive amounts but some pull has gone.
Not sure what to do TBF keep it for the sound or go back to stock just for a slight boost advantage. I.m pretty sure it's probably just the Split R settings.
« Last Edit: 15 May 2014, 18:02 by Sonic B0000M »
Offline Dalo Harkin
« Reply #8 on: 16 May 2014, 08:29 »
did your splitter valve come with the extra part to make it a full recirc? (from memory both parts come with the valve) as it isn't uncommon for people to have issue with the splitter as opposed to the full recirc.
If you want noise from the induction kit fit an S2000 filter, it was so noisy I took it off and went back to an airbox!
  • 1.8 T AUM 205BHP
« Reply #9 on: 16 May 2014, 15:17 »
I've sorted it now, just had to play around with the clicks on it. think i'm on around 16 or 17. Just a fast as before but sounds loads better.
