Author Topic: Wing mirrors while reversing  (Read 3961 times)
Offline mrzen
« on: 09 May 2014, 11:23 »
Hi all - quick question...
My wing mirrors are set to dip down while reversing which is a useful feature, however, only the passenger side one seems to do it and only when the little wing mirror joystick is pointing at the L mirror.
Is that correct, or is there something wrong with my driver's side mirror? It doesn't seem to heat up to demist either, so I think there may well be a loose connection or something... The drivers side folds back and adjusts fine, just doesn't dip or demist...
Matt
Current
2014 GTI, PP, DSG, 5 door, Nav, Tungsten Silver
2009 Audi A4 2.0 TDI Estate
Previous
2008 Audi A3 Sportback S-line 170 TDI DSG/Stronic
2004 VW Golf V 2.0 TDI 140 Manual
1999 BMW 325i M-Sport
Offline Gingernick
Re: Wing mirrors while reversing
« Reply #1 on: 09 May 2014, 11:31 »
yes its only the passenger side that dips...they will also only demist if have it set on the mirror control and have the rear screen demister turned on
the dipping is a feature set in the setup on the infotainment screen though rather than from the control knob if I remember correctly
3dr Gti, manual, tornado red, performance pack, dynaudio. gone now
5dr GTi, manual, red, Performance pack, dynaudio
going
5dr Gti, Manual, performance pack , indium grey (for a change!)
Offline mrzen
« Reply #2 on: 09 May 2014, 11:32 »
Ah ha - thanks Nick...
Current
Previous
Offline mcmaddy
« Reply #3 on: 09 May 2014, 12:55 »
Mine demist without the rear screen on.
Offline CR4ZYHOR5E
« Reply #4 on: 09 May 2014, 19:04 »
Yeah think mine demists without rear screen on too.
Offline itavaltalainen
« Reply #5 on: 09 May 2014, 22:03 »
yes, will demist if its on heated mirror position
Offline dippy_x
« Reply #6 on: 10 May 2014, 05:35 »
The heated mirror setting is one of the worst setups I have ever seen.  Don't know if it's the same as in previous golfs but I find having to to twist that knob clockwise and disable the mirror dip to enable the heat too much work!  If you twist the knob anti clockwise it's less notches but you end folding your mirrors on the way.  In previous motors the wing mirrors heat if you turn on the rear screen heater or there has been a little button to press which heats the mirrors for a short length of time.  They could have had it setup so that you press the knob to heat the mirrors for five mins?  Would have been a much better setup.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
Offline SRGTD
« Reply #7 on: 10 May 2014, 10:30 »
Yes, it's the same on the mk6. I've inadvertently folded my mirrors in while driving, when I meant to set them to demist!
Gone but not forgotten;
2016 Polo GTI; Blue Silk
