Author Topic: 1.8t aum low rev surge between 1500 2500k  (Read 3222 times)
Offline reedy20vturbo
« on: 02 May 2014, 23:40 »
As above, does anyone else get this sometimes? If it doesn't surge it'll be a flat spot instead, sometimes it'll fine but other times it'll do that,  cheers
Offline northeast_gti-t
  • "1.8T AGU"
Re: 1.8t aum low rev surge between 1500 2500k
« Reply #1 on: 03 May 2014, 23:43 »
worth checking for any fault codes firstly as this can be one or two different things
2000 Mkiv GTi 1.8T AGU
« Reply #2 on: 05 May 2014, 15:03 »
Got the 17705 code but it comes at goes, I've replaced my maf sensor (genuine) because when I disconnect it, the car won't surge or anything when I replaced it, everything was good for a day or to and it's doing it again so I replaced it again on Tuesday and it's doing it again now so it can't be that, I just thought its strange why it doesn't do it when the maf is disconnected?
Offline AD1.8T
« Reply #3 on: 05 May 2014, 18:48 »
Mine does it alot no idea what it is as I have no codes coming up. It is annoying though occasionally the mrs thinks I boot it and gives the "look" I dont think she believes me that its actually the car
« Reply #4 on: 06 May 2014, 07:50 »
Haha, yeah same here mate! Somedays it worse than others, and sometimes it won't do it at all, must be a leak somewhere but Finding leaks is a nightmare! :)
Offline AD1.8T
« Reply #5 on: 07 May 2014, 18:05 »
Would a boost leak cause it to do that ? Mine really gets on my nerves sometimes no matter what gear im in it will do it between 1 and 2.5k
Offline dom
  • Back in a Mk4
« Reply #6 on: 07 May 2014, 18:27 »
It could be a boost/vac leak although it shouldn't really be boosting before 2.5k
« Reply #7 on: 07 May 2014, 22:46 »
Finally someone with the same problem! That's the exact same thing that happens to me, disconnect your maf and try, mine won't do it with it disconnected, it will put your traction control light on as well as engine management light, I've tried the best I can to look for a leak but all the hoses are like new,
Offline dom
  • Back in a Mk4
« Reply #8 on: 07 May 2014, 22:52 »
If you unplug your MAF and the running improves then your MAF is probably faulty.
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #9 on: 08 May 2014, 08:37 »
I get the same kind of thing but only in first gear. Sometimes the slightest pressure on the throttle and it shoots through the revs other times it's flat with no power! Baffled!!
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
