Author Topic: Parking sensors  (Read 2074 times)
Offline Snooze
Parking sensors
« on: 01 May 2014, 21:43 »
So got in my car yesterday and my parking sensors just made a high pitched beep, weren't working and the light by the gear stick was flashing. Has anyone else experienced this? Think they are broken :-(
« Last Edit: 01 May 2014, 21:45 by Snooze »
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline Snooze
Re: Parking sensors
« Reply #1 on: 02 May 2014, 20:45 »
Surprised no one else has had this issue. Bit worried now! Car is out of warranty
Offline Mattyj
Re: Parking sensors
« Reply #2 on: 02 May 2014, 20:48 »
Not got parking sensors but i'm an aircraft electrician possibly there could be a short/water ingress somewhere kind of a shot in the dark but a sensible one
Offline Rhyso
Re: Parking sensors
« Reply #3 on: 02 May 2014, 21:01 »
As above
Its usually just one sensor that has failed
VCDS should be able to pinpoint which one
Offline Snooze
Re: Parking sensors
« Reply #4 on: 02 May 2014, 21:16 »
Thanks guys. Trip to stealers it is then :-(
Offline Rhyso
Re: Parking sensors
« Reply #5 on: 02 May 2014, 22:46 »
Nooo check out the VCDS user location on the forum
Or consider investing in it yourself. You soon get your money back by not visiting the stealers. Plus you can help out local people for beer tokens  :wink:
Offline Snooze
Re: Parking sensors
« Reply #6 on: 14 May 2014, 20:33 »
So stealer tells me the fault is either with the control unit or one of the front sensors. They want £230 to do more tests. I told them to jog on! Luckily they didn't charge me anything as they didn't actually carry out any work apart from plugging it in to a diagnostics machine. Can't believe this doesn't pin point the problem. Oh well just have to go old school and actually look where I'm reversing ha ha!
Offline Rgdogg
Re: Parking sensors
« Reply #7 on: 14 May 2014, 21:03 »
Try an auto electrician! I had a problem with my parking sensors on my old merc and the independent specialist wanted £140 to fix it, took it to this auto electrician who fixed it for £15. Might be worth a try.
Gti, Candy White, 3door, DSG, Leather, Rear LEDs, Bluefin, Milltek, vwr intake, Focal speakers.
Offline RedHP
Re: Parking sensors
« Reply #8 on: 14 May 2014, 21:16 »
£230 !!...No chance !
If they think that possible issue/test would be that of a single sensor then you could do this yourself. Press sensor button and test each sensor by standing away and using a long stick to 'activate' each one individually.
If that fails then maybe an internal sensor issue, but defo not for £230 !!!
Red
Mk6 GiT since birth in 2010
YNWA
Offline -car-
Re: Parking sensors
« Reply #9 on: 18 May 2014, 20:00 »
When I had my E46 parking sensor failures were a comon feature of ownership. One way of telling if they worked was that the sensors emited a clicking noise whilst in operation so it was easy to listen for the one which wasn't working.
I don't know if VW ones work the same but it maybe worth checking.
