Author Topic: K03 to k03s map  (Read 1398 times)
Offline paultownsend
K03 to k03s map
« on: 26 April 2014, 15:52 »
Gents. Think I have sourced a crack free low mileage k03 052.
If I bolted it on with new gaskets etc, would I be able to use it daily until remapped?
The car is already mapped to 185hp and 220lbft. Boosting to 16psi and never dropping below 10psi.
I have since fitted a forge tip, 3" DP and THS FMIC.
Offline davidgtrr34
Re: K03 to k03s map
« Reply #1 on: 26 April 2014, 17:58 »
Yes it will work fine
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Re: K03 to k03s map
« Reply #2 on: 27 April 2014, 17:14 »
Would the safest bet be unplug the n75 so it runs actuator pressure?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: K03 to k03s map
« Reply #3 on: 27 April 2014, 18:27 »
can do or just resist the temptation to stick your foot down lol
Re: K03 to k03s map
« Reply #4 on: 27 April 2014, 20:55 »
Well I want to check it will boost properly and doesn't smoke!
Would I expect it to boost to say 20psi, just not fuel properly?
Offline Dalo Harkin
Re: K03 to k03s map
« Reply #5 on: 28 April 2014, 12:20 »
as long as you check for play in it, you should be fine to fit it
