Author Topic: MOT Emissions help  (Read 4410 times)
Offline GolfGL
MOT Emissions help
« on: 24 April 2014, 21:39 »
Hi, So today my mk3 Golf GTI 2.0 ADY failed its MOT on emissions - if only i had booked it at the start of the month rather than a day or due before its run out.
My mechanic said give it a good service, only problem is its just had oil and filter, leads, cap and rotor arm so then said try not new catalytic converter and lambda probe. Before spending £100 on parts from ECP followed by a morning on my back trying to fit the damn thing anything worth testing/trying?
I've seen the ECT sensor test so will give that a try.
Also worth noting shes always seemed quite thirsty but put that down to short journeys, runs a little lumpy on tickover but goes pretty nicely for its mere 115 ponies, never had any starting issues.
Thanks
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline tweed
Re: MOT Emissions help
« Reply #1 on: 24 April 2014, 21:49 »
Could be a lambda
Offline GolfGL
« Reply #2 on: 24 April 2014, 21:54 »
So if the ECT sensor aint the issue just bite the bullet and go for cat/lambda.
Offline tweed
« Reply #3 on: 24 April 2014, 21:59 »
I dont want to advise that. Check wires etc first.
Offline itavaltalainen
« Reply #4 on: 24 April 2014, 22:31 »
any fault codes??
in any case lambda before replacing cat... but get something decent, not the cheap as chips ones off ebay
Offline GolfGL
« Reply #5 on: 24 April 2014, 22:54 »
I have a handheld scanner but it doesnt seem to read anything from my mk3, reads the TT, my old leon cupra r and families cars fine though.
Been looking at replacements and everythings fairly similarly priced other than VW's own £415 cat, was most likely going to get a React cat and Bosch sensor from ECP.
By the time its up on ramps and with the probe probably welded in place its probably a safer bet to do all in one job but fingers crossed its the cheaper ECT sensor option.
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 24 April 2014, 23:55 »
I do an NGK lambda for £60 or bosch for £65 (both direct fit so no chopping wires like some!)
and my cats are £58 by BM Catalysts or a similar respected brand (not like the non type approved one's sold by euro)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 25 April 2014, 06:25 »
Ive got a decent cat and lambda sensor from a 16v you can have for a tenner a piece if they're compatible mate?
Offline GOLF-MK3-GTI
« Reply #8 on: 25 April 2014, 11:33 »
Give it a good long run and then take it for emissions or get them to pass emissions test using another car.  :grin:
  • Back in a Mk3...
« Reply #9 on: 25 April 2014, 14:46 »
16v parts are not compatable, oh and GOLF-MK3-GTI do you use the same mot place i do? :lipsrsealed: :whistle:
