Author Topic: MOT Emissions help  (Read 4394 times)
Offline Therusterman
Re: MOT Emissions help
« Reply #10 on: 25 April 2014, 15:04 »
Give it a good long run and then take it for emissions or get them to pass emissions test using another car.  :grin:
Shocking!  :whistle:
See if you can get the codes read, but sounds like a lambda issue
Offline tweed
« Reply #11 on: 25 April 2014, 16:02 »
The 16v cat will fit the 8v  :wink:
Offline boneybradley
  • Back in a Mk3...
« Reply #12 on: 25 April 2014, 18:55 »
yeah same part by bm catalysts for 8 & 16v
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #13 on: 25 April 2014, 20:17 »
I thought so.
Offline hobbiniho
« Reply #14 on: 25 April 2014, 20:30 »
take it for a "hot run/thrash" before you go for the mot and get them to test the emissions straight away, i had to do this with my mk3 and the cats were pretty much glowing  :laugh: but it worked  :cool: although it may have had something to do with the fact i had 2 cats :lipsrsealed:
Offline GolfGL
« Reply #15 on: 25 April 2014, 20:56 »
So i tested the ECT sensor this evening - values seemed pretty normal and followed the table roughly thats in the maintenance section even though i didnt know exact temperature. Ran ridiculously rich and stench of fuel was terrible when the sensor was disconnected so im pretty certain its not running that rich when everythings connected normally.
Lambda and Cat tomorrow then :cry: Thanks for the parts offerguys but need it done tomorrow so its going to be ECP just need to work out which damn one it is as there are multiple Bosch lambda listings and 2 choices of cats.
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
VW BUSH
« Reply #16 on: 26 April 2014, 11:32 »
Don't use the ecp in hannibal way Wallington.....
If you can take it all off the car and go down with it, you should come back with the right bits as you can check your self, also helps with the 'its not the right part' argument.
Wallington is ok if you get the Zim, he knows his vw.
How far from Sutton are you?
Offline GolfGL
« Reply #17 on: 27 April 2014, 23:41 »
Now that was a long job. Started early saturday so i could check i had the right parts before all the shops closed. As the longlife systems only been on a year i had the parts off the car in about 45m-1hour just took a while working out where the lambda end connection was as it looped around so i was looking at the right connector the whole time i thought i wasnt. :whistle:
Then went to buy/collect parts and wasted about 4 hours calling everywhere trying to get a lambda. Next time i need to remember to check ECP stock after you get past click and collect stage. Rueben at Tuningwerkes luckily came through although it was about £20 more than ECP but i cant really complain to get the job done on the day.
All went back together ok but after refitting i found there was a small leak where cat joins the mid pipe so i then had to disassemble again to add some slots in the mid pipe to allow it to close up more, not easy handling a hack saw with a few inches of movement.
Feels like an entire day wasted but at least its now done. Ready for a retest!
Offline GolfGL
« Reply #18 on: 29 April 2014, 21:04 »
For anyone not bored of the thread yet and interested in the result, she passed today :grin: so the combination of the lambda and cat reduced the CO2 to below the threshold it was at 0.6 with the limit 0.3 and safely made it to 0.13.
Of course it couldn't be all good she needs new rear discs
Adam
