Golf mk4
Wazzzer
Turbo Actuator
Topic: Turbo Actuator (Read 1709 times)
viperjsy
Turbo Actuator
23 April 2014, 19:25 »
hi how can I tell if the Turbo Actuator is not working. The car boosts to 0.4 bar. what sould the a standard agu boost to thank you
Last Edit: 17 May 2014, 17:11 by viperjsy
viperjsy
Re: Turbo Actuator
17 May 2014, 17:12 »
would the actuator cause it to boost that low
Chris.
Re: Turbo Actuator
20 May 2014, 01:11 »
6psi. about right for a stock AGU tbh.
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
mcgee9t2
Re: Turbo Actuator
20 May 2014, 12:34 »
iv always been told aroun 8-10psi is standard.
viperjsy
Re: Turbo Actuator
22 May 2014, 01:33 »
my boost gauge is inn bar it boosts to 0.4 bar is that the same a 6 psi
Last Edit: 22 May 2014, 01:37 by viperjsy
Dalo Harkin
Re: Turbo Actuator
22 May 2014, 13:04 »
Quote from: viperjsy on 22 May 2014, 01:33
Yes
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
viperjsy
Re: Turbo Actuator
Reply #6 on:
22 May 2014, 16:39 »
thank you
Dalo Harkin
Re: Turbo Actuator
Reply #7 on:
23 May 2014, 08:26 »
no problem
Golf mk4
Wazzzer
Turbo Actuator
