Golf mk4
Wazzzer
MPG - problem or 'normal'
Topic: MPG - problem or 'normal' (Read 2694 times)
Dalo Harkin
22 April 2014, 12:51 »
I filled up the other week and managed to get 280 miles out of a full tank.... mixed driving, Now I do know that my pre cat sensor is buggered so I will be changing that soon, but it just seems low to me
anyone else know roughly what they get with the same/similar spec
Spec is in the sig
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
dom
10k hero
Back in a Mk4
Re: MPG - problem or 'normal'
22 April 2014, 13:27 »
My spec is pretty similar to yours and I struggle to get more than 280 miles mixed driving. Even a full tank on the motorway doesn't see more than 330ish.
Dalo Harkin
22 April 2014, 14:57 »
good to know, Cheers Dom
benmanc
Here all the time
22 April 2014, 16:46 »
I get around 240 mixed and 330ish motorway
GTi_James
22 April 2014, 18:10 »
I done ipswich to Norwich and back on a full tank, maxed at 42.1mpg at the end of the trip, went just under the full marker, I'm dreading a remap lol
1.8Tgolf_Chris
Here all the time
Mk4 1.8t AUM
22 April 2014, 23:01 »
some of the r32's see more than that
barrym381
Forum addict
Reply #6 on:
22 April 2014, 23:06 »
Quote from: 1.4golf_Chris on 22 April 2014, 23:01
only on the back of a truck
dom
10k hero
Back in a Mk4
Reply #7 on:
23 April 2014, 08:48 »
An R32 may see slightly more than a 1.8T cruising in 6th on the motorway, but most other driving it won't.
gm8
Reply #8 on:
23 April 2014, 09:57 »
best i have had is 420 from a tank , but mine is standard map
Dizzie
Forum addict
Make friends with your fast
Reply #9 on:
23 April 2014, 10:54 »
I can't believe you petrol lot get such crappy miles out of a tank full. If I don't get 550 out of a tank I'm disappointed. I regularly see 600+ with a max of 630 miles.
I don't see how I could ever afford to run a petrol car these days.
Mine's running 185bhp/320ft/lb so very able if you want it to be
Mk4 Golf 150PD
Golf mk4
Wazzzer
