Author Topic: Does anyone use FK dampers? Under £85 a set!  (Read 2248 times)
Offline paultownsend
« on: 20 April 2014, 17:50 »
I am over hauling all suspension on my 1.8t FWD. Already have OE hight Sachs springs to go on. Was planning Bilstein B4's at £180 a set. But I have just seen the below for £ 85 posted from Germany.
Tuning FK Automotive | Shock absorbers separately
All TUV approved. Said to be 30% up rated.
Does anyone have experience of FK? Or is this tat I should avoid?
« Last Edit: 20 April 2014, 17:52 by paultownsend »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Does anyone use FK dampers? Under £85 a set!
« Reply #2 on: 20 April 2014, 21:06 »
Got to say I'm tempted...
« Reply #3 on: 20 April 2014, 21:34 »
It's either these or the Bilstein b4's. These are less than half the price.
I know the b4's are tried and tested. Also I'm not sure if the shortened dampers will work with OE length springs
Offline itavaltalainen
« Reply #4 on: 20 April 2014, 22:03 »
FK are fairly cheap, in the sense of they are cheap and feel it.
Go Bilstein B4 or Monroe Reflex....
Offline daz veedub
  • Operation 1.8t bolf
« Reply #5 on: 21 April 2014, 09:19 »
Just fitted these on my car great for the price but you have to drill out the support top mount a couple mill for these to fit through
« Reply #6 on: 21 April 2014, 11:30 »
It was your thread I saw them on :)
Offline dom
  • Back in a Mk4
« Reply #7 on: 21 April 2014, 18:32 »
Based on the update I've just seen from Daz I'd avoid them :undecided:
Offline boneybradley
  • Back in a Mk3...
« Reply #8 on: 21 April 2014, 22:31 »
As an FK dealer (and i have used this brands shocks on a few of my cars), part FKZZVW41 is currently out of stock. Should be back available in 14 days and I can do them for same money (saves having to deal with Germany!)
Offline daz veedub
« Reply #9 on: 21 April 2014, 22:39 »
Can you get the rear support top mounts that actually fit on these shocks ? Rather than have to drill the standered 1s
« Last Edit: 21 April 2014, 22:42 by daz veedub »
