Author Topic: Fitting a whiteline under shaft rollbar  (Read 2351 times)
Offline spudboy6
  • Just like a golf ......
« on: 19 April 2014, 11:29 »
On the front I want to fit a whiteline under drive shaft anti roll bar
The previous owner removed my rollbar as it rubbed .
If I fit the under shaft whiteline bar will my standard downwards drop links still fit ?
My droplinks go from the bar to the lower arms ?
Only questioning this as from the pics the whiteline bar finishes in an upwards position ?
Its for a seat leon which is the same as a mk4 and seatcupra.net don't seem to share any info or want to help !
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fitting a whiteline under shaft rollbar
« Reply #1 on: 19 April 2014, 12:43 »
Yes standard drop links will fit mate, they just look like they come back on themselves to join up to the arms
Offline spudboy6
« Reply #2 on: 19 April 2014, 19:23 »
Thanks mate
Dpm recommended me some adjustable drop links and there another £100 !
So standard links should suffice
Thanks pal
Offline dom
  • Back in a Mk4
« Reply #3 on: 19 April 2014, 20:54 »
Standards will fit, they'll be at a funny angle though.
Offline spudboy6
« Reply #4 on: 19 April 2014, 22:17 »
I've found a front rollbar off a golf 2.8 4motion
Am I'm right in thinking this will cure my problem with this and some adjustable drop links ?
281305181339 - eBay item
Thanks for your help guys !
Offline dom
  • Back in a Mk4
« Reply #5 on: 19 April 2014, 22:55 »
That'll do the job :afro:
I wouldn't bother with adjustable drop links though, although if you are going to get some PM me and I'll send you links to everything needed to make these:
They cost about the same as the cheapest adjustable ones on eBay but have a rose joint and ball joint to help them sit properly.
Offline davidgtrr34
« Reply #6 on: 20 April 2014, 01:42 »
How did the car handle without the rollbar. Mine rubs so I want to remove it
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline spudboy6
« Reply #7 on: 20 April 2014, 11:27 »
It's not great , throw it in to a corner and it just under steers off to one side and the arches soon catch the wheels
So id rather have one fitted , from the advice  dom has given me I got a under shaft second hand bar off a golf for £42.50 and ordered up them droplinks for about £45 and the polly bushes are £15 so its a dam sigt cheaper than a whiteline bar and still retain some handling
Offline davidgtrr34
« Reply #8 on: 20 April 2014, 13:43 »
Thanks was your car lowered and stiff
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 20 April 2014, 14:39 »
Those drop links are spot on, they're a damn sight cheaper than any well known brand and links plus they are rose/ball jointed so will move in any direction thrown at them :afro:
I should take some commission off the bloke lol
« Last Edit: 20 April 2014, 14:42 by Wazzzer »
