Author Topic: cd changer  (Read 1227 times)
Offline Robin Shields
cd changer
« on: 16 April 2014, 13:41 »
I have just got my golf 1.8 turbo and want to fit a cd changer as  the one that should be fitted is missing does it have to be the standard vw changer or can I fit any make and should there be a cable for one in the boot where it should go the car has the standard vw cassette player and radio also the cd player problem is when I try to play a cd the display says no cd changer.Would like some help with my small problem love the car but also love my music
Offline Dizzie
  • Make friends with your fast
Re: cd changer
« Reply #1 on: 23 April 2014, 11:36 »
you can fit an aftermarket changer in there yes, but would need some addition cables/adaptors. I believe Autoleads do these which allow you to run a Sony? changer. You would need to run the cables to the boot yourself though.
The factory VW changer in the DIN slot above/below your existing cassette radio would be a simpler and easier way of doing it though.
Not sure if both or only 1 of the versions will run the changer though. I think there was Gamma and Beta versions.
Mk4 Golf 150PD
Offline gm8
Offline Dalo Harkin
Re: cd changer
« Reply #3 on: 23 April 2014, 12:22 »
just buy an aftermarket CD player that takes a USB stick / SD card, you can fit a lot of music on then  :wink:
