Author Topic: vr6 timing chains  (Read 5723 times)
Offline sharki786
  • GOT BOOST??
vr6 timing chains
« on: 14 April 2014, 11:56 »
Im thinking about doing the chains on a vr i have out atm. Which make kit shall i get? Febi?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline boneybradley
  • Back in a Mk3...
Re: vr6 timing chains
« Reply #1 on: 14 April 2014, 12:52 »
A lot of people will say only go o.e but I have sold several febi kits and no issues reported
The late timing chain kit by febi is £150 (free delivery)
I can also do a full top end kit (gasket set, head bolts and chains) for £280
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 14 April 2014, 13:32 »
When you say you sold several kits. How long has it been? As im abit iffy on the febi now as their top mounts fail quiet abit.
*****MK4 GTI T*****
Offline tweed
« Reply #3 on: 14 April 2014, 13:37 »
How many miles your engine done?
  • Back in a Mk3...
« Reply #4 on: 14 April 2014, 13:45 »
Regarding the top mount failure.... The vast majority were bought from a certain on-line ebay shop (maybe it's just coincidence they have a bad batch?)
The chain kit's I have sold have only being over the last few months but speaking with my supplier they have never had a febi chain returned as faulty (same goes with the top mounts).
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 14 April 2014, 15:50 »
137k tweed
*****MK4 GTI T*****
« Reply #6 on: 14 April 2014, 21:57 »
Febi will be fine, I believe the issue is more to do with the tensioner breaking up hence why the later ones were modified.
Offline tweed
« Reply #7 on: 14 April 2014, 22:04 »
137k tweed
As wayne just said. I doubt the chains will fail, but the tensioner will and if its not been done before and you're getting a slight rattle then its worth doing as piece of mind.
Lets face it when have you heard of a vr6 chain failure?
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 14 April 2014, 22:40 »
137k tweed
well im i  2 minds to do the chains as i have now found out that they aint been done. Also as i will be replacing the clutch i thought why not? Tbh tweed never heard of them failing lols
*****MK4 GTI T*****
  • Back in a Mk3...
« Reply #9 on: 14 April 2014, 22:57 »
I agree about never failing but as the engine needs to be out, would you risk using the old chain? (It's impossible to tell if it has stretched or links loosened)
