Author Topic: Rear Wheel Bearing Assy  (Read 5340 times)
Offline Olifran
« on: 14 April 2014, 10:47 »
Hi,
Has anyone changed their rear (offside) wheel bearing assy?
Looks quite an easy job apart from breaking the torque on the calliper frame bolts and the bearing assy bolt (150lbs/ft!   :shocked:)
Not sure if I fancy doing that while on axle stands!
Are SNR bearings any good? Can get the assy for £75 from eurocarparts.
Reason I’m changing mine is that there is a drone coming from rear offside. Tyre doesn’t look like it’s got any sawtooth on it and also tried my spare tyre and it still made the noise.
Thanks
Chris.
Now - MK7.5 R in Pure White with DCC.
Gone - 2014 Mk7 GTI DSG Pure White - Discover Nav - Park Assist - Winter Pack.
Offline Mattyj
Re: Rear Wheel Bearing Assy
« Reply #1 on: 14 April 2014, 11:42 »
Caliper frame bolts easy! The hardest bit will be cracking the centre spline bolt off that holds hub to assy
Offline Olifran
« Reply #2 on: 14 April 2014, 13:14 »
Could I do that one while the car is still in the ground?
Offline Mattyj
« Reply #3 on: 14 April 2014, 13:53 »
Defo thats the safest way wheel centre cap out chock wheel breaker bar and a scaffold pole
Offline ttdan
« Reply #4 on: 14 April 2014, 20:12 »
Agreed. But remember you need to get the torque back in the when installing the new bearing. Its something like 150 foot il and the half a turn...so keep the scaffold pole around  :laugh:
Offline Mattyj
« Reply #5 on: 14 April 2014, 20:45 »
Sorry to get boring but adding tge scaffold pole to a torque wrench will change the torque you'ill have to work it out i'll get bk to you with calculation can't remember off hand
Offline Mattyj
« Reply #6 on: 14 April 2014, 20:48 »
Required trq x original length over original length + extension
Offline andyr
« Reply #7 on: 15 April 2014, 08:52 »
Why would adding an extension bar/scaffold pole (of any length) to a torque wrench change at what point the wrench went "click"?? It would click at the set torque... It's up to you to stop applying force at that point! All the bar is doing is changing the applied force needed to reach the required setting.
Mattyj, I think the calculation you posted is for calibration of a torque wrench where it's imperative to know where the applied pressure is on the handle?
« Last Edit: 15 April 2014, 09:18 by andyr »
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Mattyj
« Reply #8 on: 15 April 2014, 11:27 »
Wrong google it
Offline Olifran
« Reply #9 on: 15 April 2014, 13:02 »
Well i think im going to let someone else do it as I cant be bothered buying all the necessary equipment that my toolbox is lacking and i dont want to get stuck trying to break the torque or re-apply it to the new one. Had a few interesting quotes for labour as follows:
Mobile Mechanic A - £30
Mobile Mechanic B - £50
Lookers Preston - £117!!  :grin: :rolleyes:
ICA (Ian Collins) - £75 + VAT
« Last Edit: 15 April 2014, 13:05 by Olifran »
