Author Topic: Rear Wheel Bearing Assy  (Read 5341 times)
Offline Mattyj
Re: Rear Wheel Bearing Assy
« Reply #10 on: 15 April 2014, 16:06 »
£30? Thats pretty dam cheap
Offline Olifran
« Reply #11 on: 15 April 2014, 19:07 »
Yeh, most coming in around 1 1/2 hours labour mark. Mainly between £50 to £80. No one got back to me yet as I want it doing in the am tomorrow. Toying with buying the spline bits and breaker bar and doing it myself.
Now - MK7.5 R in Pure White with DCC.
Gone - 2014 Mk7 GTI DSG Pure White - Discover Nav - Park Assist - Winter Pack.
Offline andyr
« Reply #12 on: 15 April 2014, 19:10 »
Wrong google it
I did...
Only time an extension bar changes the torque setting is if a 'crows foot' extension is used.... Which is an extension between the bolt/nut being tightened and the end of the torque wrench.
And yes £30 is pretty damn cheap, not worth getting the axle stands out  :smiley:
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Mattyj
« Reply #13 on: 15 April 2014, 19:20 »
Well i studied engineering thats we got told
Offline Mattyj
« Reply #14 on: 15 April 2014, 19:33 »
Here is a typical problem:
You have an adapter 42" long and you want to acheive a torque at the nut of 256 lbs.ft.
Your torqye wrench is 18" long.
So, using the above letters:
A = length of torque wrench = 18
B = length of adapter = 42
C = torque wrench setting = ?
D = desired torque at end of extension = 256
So, with your 42" extension on your 18" torque wrench, to acheive 256 lb.ft at the nut you need to set your torque wrench to 76.8 lbs.
Offline Olifran
« Reply #15 on: 15 April 2014, 20:11 »
Can someone just confirm it's 180NM plus another 180 deg for the 18mm bolt.
Offline ttdan
« Reply #16 on: 15 April 2014, 21:03 »
Wrong google it
I did...
Or a torque multiplier. Adding a bar wont add torque to a torque wrench, it will still go click were where you set it to. My point was that you will need the bar/pole to get the nut the extra 180, any torque wrench will reach its max possible torque with its own length of handle anyway. Yes 180nm, see below for mk5
http://workshop-manuals.com/volkswagen/golf-mk5/running_gear_axles_steering/rear_suspension_drive_shaft/assembly_overview_wheel_bearing_housing_trailing_arm_(front-wheel_drive)/removing_and_installing_wheel_bearing/wheel_hub_unit/
Offline Mattyj
« Reply #17 on: 15 April 2014, 21:33 »
Wrong google it
I did...
[/quote
Its no different to adding a pole to a spanner the torque wrench is designed to supply the torque set at that length i.e the length of the torque wrench end of
« Last Edit: 15 April 2014, 21:36 by Mattyj »
Offline andyr
« Reply #18 on: 15 April 2014, 22:03 »
I think in this equation the extension is *between* the nut and the torque wrench.
Offline ttdan
« Reply #19 on: 15 April 2014, 22:23 »
Yep. Else you would have to change the setting if you held a torque wrench half way down the handle..
