Hi, I bought my car with some HID headlights already installed, and from what i can tell, they are awful. Im not sure if it's just because they aren't correctly adjusted, or if it is just a really bad bulb.
So the first question is how do i adjust these headlights properly? (i have tried to adjust them using the white allen key bolts, but it didn't seem to make much difference. Is there something i can do on my Vag Com to adjust them? or is it a manual job? (dipped beam)
My second question is that the full beam is barely what my dipped beam used to be on my old car, and it is also circular (when on the beam just creates an illuminated circle in front of me).
Right now I'm just looking for a way to fix this as it is quite dangerous to drive with the headlights as they are.
Also, how would i go about fitting oem bulbs again? is it a straight fit, or is there anything that i need to change? i've noticed that it looks like there is additional wiring with these current lights.
Thanks, Mo
