Author Topic: Mk4 Golf Injector Replacement  (Read 3275 times)
Offline jamiesgolf
« on: 09 April 2014, 18:28 »
Hi Guys, recently replaced an injector in my golf and it hasn't fixed the problem. I heard today that some manufacturers make it so that the injector has to be programmed in order to work, apparently Ford do so. Is this just for Fords or do VW have a similar policy?
thanks for any help in advance
Offline james2
  • No scammers please.
Re: Mk4 Golf Injector Replacement
« Reply #1 on: 09 April 2014, 19:51 »
How would you program a injector. Whats wrong with your car to say its a injector. Does it get power and have you had the inlet mainifold off ? a air leak on one cylinder made me think my injector was not working until i removed the inlet mainifold and there was a washer behind it.  :laugh: i blame my old man rushing me.  :whistle:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline jamiesgolf
« Reply #2 on: 09 April 2014, 21:04 »
thanks for your reply. I had a misfire so ran diagnostics and it came back with the code relating to the injector/ injector wiring. I don't mean program the injector, i'm not really sure how it works i just heard that apparently for fords it has to be done by a dealer. i posted previously on this forum about the issue, I replaced the injector, and ever since the electrical connection to the injector has been getting fuel in it, in all cylinders despite the fact i didn't touch any other connectors. It's as if the fuel rail is over pressurised and fuel is leaking through the injector. the car doesn't run any differently - still misfires. I haven't driven it since i discovered the issue as there's obviously a bad problem. I'm thinking it must be a problem with the wiring harness but i don't know what to replace. can you buy a harness for one singe injector? or would i have to buy the whole wiring loom for all cylinders?
thanks in advance
Offline mike1990
« Reply #3 on: 09 April 2014, 23:43 »
Injector seat?
Offline dom
  • Back in a Mk4
« Reply #4 on: 10 April 2014, 10:26 »
Injector seat?
That's what I thought at first as well.
Offline jamiesgolf
« Reply #5 on: 10 April 2014, 11:37 »
Hi guys thanks for your replys, sorry i'm a bit new to this, is the injector seat the part at the bottom of the injector? I literally just took out the old injector, and put the new one straight back in, nothing else came out/ went in. Could this be the cause of the misfire? or just causing the over pressurizing of the fuel?
thanks again
Offline WadGTI
  • Golf GTI'er
« Reply #6 on: 10 April 2014, 12:33 »
thanks again
I would expect that you have got to give it a good tug to get it in/out of the rail.
As far as I know, I don't think these gen are coded. However as good practise, i took note of which ones I took out so they all went back in the right order.
On the manifold behind the injectors...is it stained? Try and take a pic and post it up. But sounds light the seats are weeping.
Offline jamiesgolf
« Reply #7 on: 10 April 2014, 15:10 »
A good tug to get the injector seat off the fuel rail? So should I take off the inlet manifold, then remove all the injectors? I'll post up a picture later
Thanks for your help
Offline mike1990
« Reply #8 on: 10 April 2014, 16:16 »
The injector seats are what the injectors "sit" into on the inlet manifold
Offline WadGTI
  • Golf GTI'er
« Reply #9 on: 10 April 2014, 16:19 »
I don't think you will get the seats out with a tug. Certainlly the injectors.
I took the fuel rail off first, twisted it around and then pulled the injectors. Its a bit fiddley as wires run trough the fuel rail. There was one wire which went to the behind the front bumper (possibly outside tmep sendor) which stopped me taking the rail off.
I would take the manifold off last and I plugged the cylinder holes as soon as I took it off to stop crud falling in. I found it easy to rip up a carrier bag in half and plug it with that.
