Author Topic: Mk4 Golf Injector Replacement  (Read 3289 times)
Offline dom
  • Back in a Mk4
Re: Mk4 Golf Injector Replacement
« Reply #10 on: 10 April 2014, 16:31 »
The injector seats are threaded so would need to be twisted off. Ideally you need a huge hex bit to get them out.
Offline WadGTI
  • Golf GTI'er
« Reply #11 on: 10 April 2014, 16:41 »
 :grin: :grin: I ended up having to shave a 21mm wheel nut in order to get them off. I tried every (shoop wise) to get one without any luck. I think ebay have them tho.
Offline jamiesgolf
« Reply #12 on: 10 April 2014, 16:49 »
Okay cool, i'll do that, so do you think it is the injector seats that are causing the over pressurising? my problem is that even if i can fix this problem, I still have a misfire that is being caused by something to do with the injectors.
thanks for all the help! it's much appreciated.
Offline dom
  • Back in a Mk4
« Reply #13 on: 10 April 2014, 16:57 »
A leaking injector seat would cause a fuel leak from the injector area
Offline jamiesgolf
« Reply #14 on: 10 April 2014, 17:00 »
right okay, i can't see any fuel leaks anywhere around the injector, it only leaks through the electrical connector :/
Offline jamiesgolf
« Reply #15 on: 10 April 2014, 17:55 »
Here are some photos, In this photo: http://i1372.photobucket.com/albums/ag332/jamieisafish/Mobile%20Uploads/image_zps9dd30ce2.jpg
you can just about see the fuel in the electrical connector.
This photo isn't great but again it's of cylinder 4 where the misfire is: http://i1372.photobucket.com/albums/ag332/jamieisafish/Mobile%20Uploads/image_zps886d854a.jpg
Cylinder 1 also has fuel in the connector as well. The injectors aren't leaking from anywhere else
Offline dom
  • Back in a Mk4
« Reply #16 on: 10 April 2014, 19:12 »
What engine is it?
Offline jamiesgolf
« Reply #17 on: 10 April 2014, 19:21 »
2.0l 8v gti
Offline Dalo Harkin
« Reply #18 on: 11 April 2014, 12:27 »
Did you replace the little rubber 'o' rings on the top and bottom of the injectors?
Offline jamiesgolf
« Reply #19 on: 11 April 2014, 12:43 »
Yep the replacement injector came with new o rings so yeah I replaced them.
