Author Topic: Judder at low revs  (Read 1535 times)
Offline Petehewitt
Judder at low revs
« on: 08 April 2014, 22:08 »
Any help much appreciated- 2001 1.8 turbo with aum engine has an intermittent fault where from cold the engine judders and surges when driving at low revs. I changed the mam but still does it. I've seem a variety of ideas but means spending a lot of ££ on coil packs, sensors etc and want to know what order I should do things in to try and track it down. It's an intermittent fault and once the engine has been driven a while seems much improved but can still be present. Also if I drive at a constant speed some times booting it puts the traction control light on and epc and have to turn the engine off and back on as I have no power what so ever- again this is intermittent . Plugged in vagcom but no fault codes- any ideas guys?
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
Re: Judder at low revs
« Reply #1 on: 08 April 2014, 23:13 »
My previous AUM did that too and it was a 2001, I did the ultimate delete sai pump and N deletes, this did sort it out.
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline Petehewitt
« Reply #2 on: 09 April 2014, 17:33 »
What is sai and n?
Offline dom
  • Back in a Mk4
« Reply #3 on: 09 April 2014, 20:10 »
What is sai and n?
Secondary Air Pump and N249/N112 valves
