Author Topic: Clutch peddle stuck to floor  (Read 3586 times)
Offline dan_thevdub_man
« on: 06 April 2014, 11:47 »
So I was about to drive to manchester sell my vr6 interior. Pulled up at traffic lights and then bang (there was no bang) the clutch peddle went to the floor. Obviously I can drive the car using the revs but what is it? Some say master, some say slave, some say the fluids. If it's either of the cylinder what kinda work are we talking?
Offline sharki786
  • GOT BOOST??
Re: Clutch peddle stuck to floor
« Reply #1 on: 06 April 2014, 11:50 »
What engine is it? 8v 16v 1.9tdi or vr?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline matty james
« Reply #2 on: 06 April 2014, 11:52 »
happened to my last gti 8v that.all it was the clip on the end of the clutch cable snapped , where it connects to the arm on the gear box
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
« Reply #3 on: 06 April 2014, 11:54 »
Mk3 8v where's the clip you talk about?
Offline matty james
« Reply #4 on: 06 April 2014, 12:02 »
theres an ar that comes off on the side of the gear box it will be swingin freely if the cable has disconected from it -there will then be a cable some were near doin nothing too
Offline matty james
« Reply #5 on: 06 April 2014, 12:07 »
the clip is only abot 30mm long it corrodes and snaps releasin the cable from the gear box arm - easy to fix - new clip and rubber block are only pennies new-assuming thats what happened to urs.
« Reply #6 on: 06 April 2014, 12:14 »
Cheers guys and if it's not this?
Offline matty james
« Reply #7 on: 06 April 2014, 12:22 »
cant help you if its not that im affraid -but check the cable and arm 1st - simple things 1st  :smiley:
« Reply #8 on: 06 April 2014, 12:25 »
Arm still looks fine and the clip (if it's right one is still attached) should I be able to move the arm?
Offline matty james
« Reply #9 on: 06 April 2014, 13:59 »
i think so , but you shouldnt be able to move it without any effort .
