Author Topic: Tar Spots  (Read 3331 times)
Offline clipperjay
Tar Spots
« on: 04 April 2014, 15:10 »
Its been awhile since detailing so decided to wash the daily and since they have filled and re surfaced the roads after winter, its has left me with loads of tar spots!
From memory I used clay once before and it was great, but can't remember how I used it last?
I've just ordered some dodo juice clay bar without lube and wanted to know if I can just use any car wash and water in a spray bottle?
 :undecided:
I've only ever used Poorboys polish sealant with super suds, dodo juice wax so any help will be a plus!
 :cool:
Offline oakgreen_91
Re: Tar Spots
« Reply #1 on: 04 April 2014, 15:22 »
I wouldn't try to get tar off with a clay bar personally, if you have an Autosmart dealer nearby get some Tardis from them - alternatively get an off the shelf tar remover from Autoglym or Meguiars at Halfrauds.
When you use the product it's very satisfying to see the tar spots running down the side of the car as they dissolve  :laugh:
2012 Audi A4 Avant Black Edition TDI 177
2012 Megane RenaultSport 250 Cup
1991 Volkswagen Golf GTI 8v
1990 Renault 5 GT Turbo
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Tar Spots
« Reply #2 on: 04 April 2014, 17:36 »
AS tardis is the best ever. Get some of egay. So effective. Use this first, and waht this doesn't remove the clay will  :smiley:
Offline Booth11
Re: Tar Spots
« Reply #3 on: 04 April 2014, 18:57 »
+1  I wouldn't use anything else.
As for lubricant for clay, car shampoo/water mix should be fine.  If you go for a dedicated lubricant, Dodo Juice Born Slippy is good.  Alternatively, Bilt Hamber clay is designed to be used with plain old water and works very well.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline clipperjay
Re: Tar Spots
« Reply #4 on: 05 April 2014, 10:37 »
Bought some autoglym Tar remover a bit expensive, but did the job!
TBF white sprite would have done the job aswell.
Thanks for the suggestions the clay bar will clean the rest up, paint not smooth as it used to be  :rolleyes:
Offline dubber36
Re: Tar Spots
« Reply #5 on: 05 April 2014, 16:49 »
WD40 / GT85 does a good job too.
Offline CraigW
Re: Tar Spots
« Reply #6 on: 10 April 2014, 23:50 »
Maxolen tar remover is another to add to the list. Does a great job  :smiley:
