Author Topic: Bonnet release catch?!  (Read 1248 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 02 April 2014, 17:29 »
I removed my bonnet release catch as I had the front slam panel off the other day. Have put it back on, in the same 'reverse' order as any good Haynes manual will tell you...But now it does not 'lock'.
You get the stage where you give the bonnet a shove to give it the final lock and it doesn't. It sits higher than the wings, in the 'stage 1' of the '2 stage' locking process.
It is well oiled/cleaned...Cannot figure it out  :huh:
Anyone?
Offline Dalo Harkin
Re: Bonnet release catch?!
« Reply #1 on: 02 April 2014, 17:40 »
when I took mine off it was literally a millimetre out on one side to where it should be - repositioned it and it was all good
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 02 April 2014, 19:18 »
the holes are elongated so it's adjustable , probably just a case of getting in the right position again
Offline scarr89
« Reply #3 on: 02 April 2014, 20:28 »
Both spot on.
I had a little play, it was probably 2mm out.
