Golf mk4
Wazzzer
F M L
Topic: F M L (Read 2260 times)
XMC1980
Here all the time
Don't piss in my pocket and tell me it's raining!
F M L
01 April 2014, 18:10 »
Yesterday we connected the two pipes that go to the front rail injectors incorrectly ie water fuel -fuel water and about £25 of fuel went into the water system. Flushed it out put new coolant in
Today twice temp went red on gauge and said stop and now it's on zero for 3-4 mins then red and repeat!
I'm about to jump off my balcony
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Nino
Re: F M L
01 April 2014, 19:41 »
Surely the garage that did this work for you should shell out for this?
Like my badge? Get one here:
https://www.golfgtiforum.co.uk/index.php?topic=291134.0
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35 - Candy White - 3 door
MoshiMoshi
GTI forum regular
Scorpion Exhausts are delightful.
Re: F M L
01 April 2014, 20:40 »
I would say its probably misreading the temperature rather than overheating? Replace the temp sensor, and maybe the thermostat too? My money would be on a knackered temp sensor. Petrol probably doesn't do it any good.
I thought Volkswagens were supposed to be reliable?
XMC1980
Here all the time
Re: F M L
01 April 2014, 20:45 »
He will happily do it but it's 100 miles away
The car does feel slow since rebuild
Mk4 1.8T 218ps AUQ
dom
10k hero
Back in a Mk4
Re: F M L
01 April 2014, 21:34 »
Did you have the waterpump replaced?
XMC1980
Here all the time
Re: F M L
01 April 2014, 21:44 »
Quote from: dom on 01 April 2014, 21:34
Yes dom water pump was done, could the faulty temp sensor make the car slow?
Mk4 1.8T 218ps AUQ
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: F M L
Reply #6 on:
01 April 2014, 21:53 »
Yes it could
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
XMC1980
Here all the time
Re: F M L
Reply #7 on:
01 April 2014, 22:03 »
Quote from: Wazzzer on 01 April 2014, 21:53
Yes it could
I'll change it tomorrow and see what happens :/ really pissed off and close to tears! The sacrifices I made this week! 1k in parts and 6 days of 12 hours fighting through it and things going wrong, then when it's all done one thing still wrong or 2 if the power loss isn't related to temp sensor
Mk4 1.8T 218ps AUQ
Nino
Re: F M L
Reply #8 on:
02 April 2014, 05:35 »
Get itbon a vag com see if it has any serious readings.
VW Car history
Current
Dalo Harkin
Re: F M L
Reply #9 on:
02 April 2014, 08:10 »
As the others have said its probably the temp sensor, make sure you use a genuine one..
did you have a new Thermostat put in too? might be worth to check it isn't sticking
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Golf mk4
Wazzzer
F M L
