Author Topic: mk4 temp gage not working!  (Read 2390 times)
Offline simon33
« on: 31 March 2014, 21:47 »
Hi guy's im new here iv just got my self a mk4 1.8t and the temp gage is not working the car also has a rough idle. I had a look on the net and found it could be the temp sensor so got a new one off ebay and it has had no effect temp is still not working! (The gage is going to dead center when the car is left sitting but as soon as i drive it it moves to the bottom again)
Could i have just got a duff sensor or could it be another problem I.E stat?
On another note iv just drop'ed the car on fk coil's and im now getting problems with the drive shaft hitting the arb is there any cheap fix for this other than a new arb that passes under the drive shaft?
Cheers Si
« Last Edit: 31 March 2014, 21:53 by simon33 »
Offline barrym381
Re: mk4 temp gage not working!
« Reply #1 on: 31 March 2014, 22:38 »
your temp problem will be your thermostat when buying a new 1 get it from tps or the dealers as cheap eurocarparts thermostats dont last long  :wink:
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #2 on: 01 April 2014, 10:36 »
Barry is spot on! Also check the temp sensor as there are different ones and you might have the incorrect one, then check the coolant whilst your at it? G12 coolant and there's a drain tap under the radiator passenger side :smiley:
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline dom
  • Back in a Mk4
« Reply #3 on: 01 April 2014, 11:31 »
Almost certainly the thermostat and as Barry says, replace it with a genuine part.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #4 on: 01 April 2014, 12:58 »
Cheers Si
+1 on what dom says its defo your thermostat get it changed and your gauge will read correctly  :wink:
with your arb issue lowering more than 50mm iirc will cause the driveshaft/arb issue you can always try fitting adjustable droplinks this may help
2000 Mkiv GTi 1.8T AGU
Offline simon33
« Reply #5 on: 01 April 2014, 19:32 »
Cheers for all the advice chaps going to fit new stat at the weekend will report back.
Re: the arb issue iv heard pug 405 drop links will sort out the proble any one know if this is true or not?
Offline reedy20vturbo
« Reply #6 on: 01 April 2014, 19:37 »
I had this same problem last week, replaced the thermostat and now it sits at 90, no matter what :)
Offline dom
  • Back in a Mk4
« Reply #7 on: 01 April 2014, 19:43 »
I've never heard that before, I'll be surprised if they do fit :undecided:
Offline simon33
« Reply #8 on: 18 April 2014, 14:16 »
Fitted new stat today only took a hour so chuffed with that and yep gage is holding steady now. Thanks for  advice chaps.
On another note I tried fitting pug 405 drop links thay fit but no joy still rubbing. Going to cut them down and weld them up shorter than standerd ones. Worth a shot I think shorter ones will do the job.
