Author Topic: Strong Smell (Again)  (Read 2491 times)
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« on: 31 March 2014, 21:04 »
Whenever I've been driving the car for a period of time (say 20 minutes on the M4) and then come to a stop, the car stinks of rich fuel. Properly stinks. I'm getting a 17705 and a 17545 (fuel trim bank 1 too rich or something). Any ideas on the cause of this?
I'm thinking: Dodgy MAF? Boost Leak? Problem with my Forge DV?
I thought Volkswagens were supposed to be reliable?
Offline dom
  • Back in a Mk4
Re: Strong Smell (Again)
« Reply #1 on: 31 March 2014, 21:11 »
You running a decat?
Offline MoshiMoshi
« Reply #2 on: 31 March 2014, 21:18 »
No, it passed the MOT on emissions a few weeks back. The cat is a little worse for wear and will need sorting next year.
« Reply #3 on: 31 March 2014, 21:36 »
That I believe is a lambda problem (I was getting the same on the vRS)
Offline Dalo Harkin
« Reply #4 on: 01 April 2014, 12:27 »
+1 I had the same when my front one was shot
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 01 April 2014, 12:51 »
 :grin: the famous 17705 fault,good luck  :whistle: http://wiki.ross-tech.com/wiki/index.php/17705/P1297/004759 this can be alot of things also been well documented here and other forums  :lipsrsealed:
 Your 17545 code http://wiki.ross-tech.com/wiki/index.php/17545/P1137/004407 as wayne has said a lambda problem  this is one of the faults to throw that code up
2000 Mkiv GTi 1.8T AGU
Offline MoshiMoshi
« Reply #6 on: 01 April 2014, 13:33 »
Thanks guys, can we be more or less sure its the front lambda at fault? And can anybody recommend one that wont cost me a fortune? I'm pretty broke at the moment and don't want to spend much.
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #7 on: 01 April 2014, 16:06 »
TPS
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline MoshiMoshi
« Reply #8 on: 01 April 2014, 20:32 »
How do I buy through TPS?
Offline XMC1980
« Reply #9 on: 02 April 2014, 12:33 »
I order through my friends garage, but they must do cash accounts, is there a branch near you?
I'd say chessington is the nearest to you
02083974333 ask for Derek
« Last Edit: 02 April 2014, 12:35 by XMC1980 »
Mk4 1.8T 218ps AUQ
