Author Topic: Is this dump valve installed correctly?  (Read 5739 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Is this dump valve installed correctly?
« Reply #10 on: 31 March 2014, 01:40 »
Wonder what's hiding under the bit if black tape?!!!
:undecided: i would be wondering that too,I'm guessing its joining two pieces of vac pipe or its been split and bodged up  :whistle:
2000 Mkiv GTi 1.8T AGU
Offline Dalo Harkin
« Reply #11 on: 31 March 2014, 08:25 »
The orientation of the DV is the 'wrong' way it gives a loud cherp noise rather than a psch. I would fit it the other 'right' way because regardless what Forge say there is plenty on the net about people having issues with them fitted the 'wrong' way
Offline MoMartin
« Reply #12 on: 31 March 2014, 10:37 »
You would be correct in thinking that it's a bodge job! It was a potential vacuum leak, so I decided to black tape it, until the new silicon hosing comes.
Also, could someone direct me to the 'correct' way of fitting a DV?
Thanks, Mo
Offline rockmonkey69
« Reply #13 on: 31 March 2014, 11:04 »
It seems it's fitted both ways with people giving different reasons for fitting it in different orientation. I've tried fitting it both ways with no difference in sound, boost or overall feel of the car. I think I'll be rotating mine around so the charge pipe feeds to the side of the diverter valve, purely for aesthetics.
Offline MoMartin
« Reply #14 on: 31 March 2014, 16:51 »
An update -  cut the silicone hosing back from where it's taped up, it wasnt that, that was causing the problem.
Once again, could someone direct me to a guide on how to 'correctly' fit a dump valve / recirculation valve?
Thanks, Mo
« Reply #15 on: 31 March 2014, 18:02 »
It seems you're assuming the diverter valve is the cause of your engine problems and that a standard car might not have had the same problems you're experiencing. It's probably more effective to do a diagnostic and maybe a boost leak test.
Offline dom
  • Back in a Mk4
« Reply #16 on: 31 March 2014, 18:47 »
Thanks, Mo
Just swap the two big hoses over
Offline MoMartin
« Reply #17 on: 31 March 2014, 21:57 »
Which hoses haha, I'm still a complete rookie at Mk4 golfs, so i have no idea which hoses do what / where everything is  :huh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 31 March 2014, 22:02 »
Nino it's an AGU so no N249 lol
Take your DV off and swap the two hoses around that are connected to it
Offline Dalo Harkin
« Reply #19 on: 01 April 2014, 08:33 »
At the moment your DV is sat horizontally, you need to take it out of both pipes and turn it vertically with the blue silicone pipe connecting at the top
