Author Topic: just smoke when standing  (Read 4979 times)
Offline Bensuv87
« on: 29 March 2014, 05:15 »
hello  just had a massive full engine rebuild on my mk4 turbo. did have a big oil leak when it was 1st put back together .
and smoke
BUT when its running its fine but give it 2 secs when you've stopped and white smoke comes and and lots of it too????? there was a bit of oil in the water from the previous garages f**k up  ????
Offline sharki786
  • GOT BOOST??
Re: just smoke when standing
« Reply #1 on: 29 March 2014, 08:30 »
Porb they didnt clean out the cylinders properly a d has left some oil/water in them so its just burning rest away. Get a pic or even better a vid of it.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
« Reply #2 on: 07 April 2014, 00:59 »
I had exactly that and it turned out to be my turbo
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline Bensuv87
« Reply #3 on: 07 April 2014, 07:04 »
WAS IS MAJORLY f**kED????? N HOW MUCH???
Offline XMC1980
« Reply #4 on: 07 April 2014, 09:26 »
Had more play than Pamela Anderson fanny! Got it rebuilt for 380£
Do a compression test first to eliminate valve stem seals, and check your oil pick up pipe and feed, take the TIP off your turbo and you will be able to feel if it has any play
Get ready to empty your pocket
Mk4 1.8T 218ps AUQ
Offline XMC1980
« Reply #5 on: 07 April 2014, 09:28 »
Bear in mind if it was overfilled with oil it could have dropped into the cat and is burning off, did you not check the turbo when you did rebuild?
Mk4 1.8T 218ps AUQ
Offline Bensuv87
« Reply #6 on: 07 April 2014, 19:09 »
i got bent over by a so called friend, really didnt end well at all.
i aint a mecanic put alot of faith n money into him and he just f**ked me.
just trying to get my bloody golf sorted.
Offline XMC1980
« Reply #7 on: 07 April 2014, 21:18 »
Mate I just been there! Got shafted with a car with a bad turbo and valve stem seals! £1700 repair bill! So I feel your pain, but you need to find out what it is first before losing faith, it might not be bad and it might be disasterous? Chin up and keep on dubbing
If it wasn't for the support I got of these guys especially
Nino
Rock
Sharki
Dalo
Northeast gti
Dom
I probably would have set fire to it
« Last Edit: 08 April 2014, 00:21 by XMC1980 »
Mk4 1.8T 218ps AUQ
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 08 April 2014, 21:05 »
Nino
Rock
Sharki
Dalo
Northeast gti
Dom
wow i feel special bro. :wink:
we all like to help others as much as!
*****MK4 GTI T*****
Offline XMC1980
« Reply #9 on: 08 April 2014, 23:24 »
Nino
Rock
Sharki
Dalo
Northeast gti
Dom
It's true bro I was on the verge! I appreciate all your help and helping each other out is what this is all about really?
Some people have knowledge or experience and others give you morale support, that was a bad week for me and I got through it :) German whip!!!!
Mk4 1.8T 218ps AUQ
