Author Topic: How much to change a Starter Motor in Bristol?  (Read 2109 times)
Offline ksab
« on: 26 March 2014, 22:17 »
I have a problem with my 2.0l GTI, when i start the engine the starter motor makes a whirring/grinding noise which lasts about 2 seconds. I've done some research and it's quite a common apparently, And it means you either need to completely replace the SM or just take it off and give it a good clean and lube before putting it back in. Problem is i know nothing about cars/mechanics. So was wondering what i would be looking at to have this done by someone? I'm in Bristol if anyone can be recommended.
Offline Lewy
Re: How much to change a Starter Motor in Bristol?
« Reply #1 on: 26 March 2014, 22:36 »
£100 for the starter, and possibly another £100 to change it.
I would avoid Graham Batts near Temple Meads as their customer service and quality have taken a nose dive.
Offline ksab
« Reply #2 on: 26 March 2014, 22:46 »
Ok cheers, i think i might give my local garage a ring in Soundwell. I just wish i know more and could do this sort of stuff myself.
Offline barrym381
« Reply #3 on: 26 March 2014, 23:06 »
look on youtube you will find a video showing you how to do it  :wink:
Offline ksab
« Reply #4 on: 26 March 2014, 23:10 »
I had a look earlier but i still don't trust myself to do it. I'd rather start off with something a bit simpler.
Offline barrym381
« Reply #5 on: 26 March 2014, 23:17 »
its a bit fiddly but sure you will manage or ask if there is a forum member local willing to help  :smiley:
Offline Tezmax
« Reply #6 on: 27 March 2014, 12:16 »
To be fair ksab if your going to start somewhere then a starter motor is perfect.
2 Bolts, 1 power cable and a electrical plug and its out. You cant really go wrong with it.
Look on youtube like Barry says and your 90% there.
Get yourself a pair of these as you will need them again owning a Golf :whistle:
http://www.ebay.co.uk/itm/1-PAIR-OF-2-TONNE-METAL-CAR-RAMPS-BRAND-NEW-PAIR-/310652401556#ht_1684wt_811
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline ksab
« Reply #7 on: 28 March 2014, 09:29 »
You mkae it sound easy, maybe i'll have a look over the weekend. i think my main worry is putting it back together again. oh well. Trial and error i guess.
I'll check Vids on Youtube.
Offline joshstanvw
« Reply #8 on: 28 March 2014, 14:31 »
It really is simple about an hour and a halls work if you have never done anything like it before if I was up that way I'd do it for I for a cuppa tea and buiscuits someone up there has got to be able to go and help
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline ksab
« Reply #9 on: 28 March 2014, 15:17 »
Aww cheers John, lol. We got tea & coffee and biscuits, Nice ones too. Milk Chocolate Digestives. Shame you're not closer. I might try and tackle it myself. I'll watch a few vids tonight and have a go tomorrow.
