Author Topic: Brakes are like sponge  (Read 1061 times)
Offline Mk2_tel
« on: 23 March 2014, 15:42 »
I fitted my brakes today to the 312mm set up yet when I bleed them I'm getting no joy.
The brake pedal is just going to floor I've done brakes in the past and never had this problem
Offline sharki786
  • GOT BOOST??
Re: Brakes are like sponge
« Reply #1 on: 23 March 2014, 16:26 »
Try to bleed the master cylinder then abs pump and then every brake. Make sure enought fluid comes out though.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline mike1990
« Reply #2 on: 23 March 2014, 16:28 »
As your bleeding the brakes, start from the caliper furthest away from the master cylinder, so nearside rear then offside rear then nearside front and finally offside front
« Reply #3 on: 24 March 2014, 23:44 »
I believe you need to bleed them a different way, you run the risk of master cylinder damage the normal way.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 25 March 2014, 12:26 »
It seems to be a bit of a dark art...
