Author Topic: Top mounts  (Read 1894 times)
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
Top mounts
« on: 22 March 2014, 21:09 »
Guys forgive my inexperience but how hard is it to change front top mounts?
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline northeast_gti-t
  • "1.8T AGU"
Re: Top mounts
« Reply #1 on: 22 March 2014, 21:16 »
Easy enough and for some guidance of whats involved  :wink: http://www.r32oc.com/topic/20110-a-diy-guide-to-replacing-mk-iv-strut-tops/
2000 Mkiv GTi 1.8T AGU
Offline XMC1980
Re: Top mounts
« Reply #2 on: 22 March 2014, 22:02 »
Mk4 1.8T 218ps AUQ
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Top mounts
« Reply #3 on: 22 March 2014, 23:23 »
A spring compressor helps massively. Piece of cake with a hydraulic one. Other wise just time consuming...
http://forums.vwvortex.com/showthread.php?5187132&p=69931648&viewfull=1#post69931648
Maybe the 5th post down + LOADS of other good how to's  :cool:
Offline XMC1980
Re: Top mounts
« Reply #4 on: 22 March 2014, 23:26 »
Thanks guys! Appreciate it very much :cool:
Mk4 1.8T 218ps AUQ
Offline XMC1980
Re: Top mounts
« Reply #5 on: 23 March 2014, 20:37 »
Providing the compression test is ok in the morning I'm going to dedicate a couple of days to the new ride.....
I am going to change top mounts maybe poly? What do you think? And as I have t change discs and pads I was thinking about making my springs look new? What's the best way to go with the springs?
Mk4 1.8T 218ps AUQ
Offline dom
  • Back in a Mk4
Re: Top mounts
« Reply #6 on: 23 March 2014, 20:43 »
Poly top mounts will be pretty harsh, I'd stick to standard replacements tbh
Offline XMC1980
Re: Top mounts
« Reply #7 on: 23 March 2014, 20:44 »
I'll take your advice thanks Dom :smiley:
Mk4 1.8T 218ps AUQ
  • "1.8T AGU"
Re: Top mounts
« Reply #8 on: 23 March 2014, 20:50 »
depends how much work you want to do  :laugh: you could get them sand/shot blasted etc then powdercoated or a quicker way is take all the old flaky paint rust off etc,coat of primer then a coat or two of colour of your choice and coat or two of clearcoat should have them looking new again :afro:
Offline XMC1980
Re: Top mounts
« Reply #9 on: 23 March 2014, 20:54 »
The first way is obviously the correct way the only problem is it's my daily drive so probably have to go the other route this time
Thanks  :smiley:
Mk4 1.8T 218ps AUQ
