Author Topic: mk2 golf electrical problem. help help help.  (Read 1574 times)
Offline benpex
« on: 15 March 2014, 21:20 »
Right guys or girls. I have a wonderful piece of joy in the form of a cl 4+E it's causing me some problems. It's been of road of nearly 7 months it's going back on road in April but just recently when I try to start it I don't get anything other than a clunk and thenit start the time after. But also when it's running after a while the cd player, wipers, blowers and electric boot lock won't work but then it will and I can't seem to find the problem.
I just don't know what the problem is and I can't seem to find it so was wondering if anyone here knows what it could be.  I'm at a loss with this and need help.
Thanks for any help
Offline Mr Blue
Re: mk2 golf electrical problem. help help help.
« Reply #1 on: 17 March 2014, 17:22 »
Could be anything. First place I'd check is fuses, then the back of the fuse box. Push all connectors /clean up and corroded connections.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 17 March 2014, 17:56 »
Moisture / corrosion in connections. Check and clean Earth leads as well.
Offline MurdieMK2
« Reply #3 on: 19 March 2014, 10:15 »
I had the same thing in my Mk2 Driver, i traced it back to a loose nut on the starter motor, holds earth to casing i think, tightened it up and she fired on the button.
« Last Edit: 19 March 2014, 11:41 by MurdieMK2 »
