Golf mk6
Snoopy
Rcd510 preouts/rcas
Topic: Rcd510 preouts/rcas (Read 3465 times)
Mattyj
Rcd510 preouts/rcas
14 March 2014, 15:47 »
Is there a in-line wiring harness i can put on my rcd510 to run an amp
Candy Man
GTI forum regular
Re: Rcd510 preouts/rcas
15 March 2014, 00:11 »
http://www.myturbodiesel.com/wiki/rns510-rns315-gps-or-rcd510-installation-in-a-mk5-vw/
This is a pin out diagram that may help m8
tenrohle
GTI forum regular
15 March 2014, 15:29 »
you could use line converters.
Mattyj
15 March 2014, 19:24 »
Explain?
legg360
GTI forum regular
15 March 2014, 22:50 »
Ive been looking into this as well, from what ive worked out you need a little box of magic that you connect a feed from a rear speaker to and it converts into an output to be sent to the amp for your sub if that makes sense?
Golf GTI MK6 5dr Manual - Candy White with Jacara Cloth, Vancouver 18" Alloys, RNS 510, Cruise Control, Carbon Vinyl Wrap Roof, Milltek 3" Race Cat Back.
legg360
GTI forum regular
16 March 2014, 00:38 »
So it turns out you need a LOC or line out converter
Connect a fed from left and right into the LOC and place behind the head unit using this wire diagram to work out what wire this will give you your RCA outs you want
http://www.my-gti.com/1313/volkswagen-rcd-510-pin-assignments
Mattyj
Reply #6 on:
16 March 2014, 12:56 »
Awesome nice one buddy thats perfect
tenrohle
GTI forum regular
Reply #7 on:
16 March 2014, 18:08 »
What he said
PD_GTI_MK6
Reply #8 on:
22 September 2015, 13:21 »
I'm in the same boat here, I have a sub and a pair of speakers (to be installed in a parcel shelf) I want to run off an amp or maybe two.
I get what an LOC does but I'm guessing I'll still need to run a remote live from the back of the RNS 510 ?
This is the LOC I was looking at:
http://www.ebay.co.uk/itm/RCA-Car-4-Channel-Line-Level-Converter-with-Remote-Out-/280598059072?hash=item4154f29840
I probably would've like to keep the stock speakers running as well but whatever's easiest I guess.
Thanks.
Golf mk6
Snoopy
Rcd510 preouts/rcas
